SE = Base Trim Level on the Magnum
SXT = Mid Trim Level on the Magnum
RT or R/T = Top Trim Level on the Magnum
300: Base trim level
300 Touring: Mid trim level
300 Limited: High trim level
300C: Top trim level
AWD = All Wheel Drive
RWD = Rear Wheel Drive
FWD = Front Wheel Drive
HP = Horse Power
ft/lbs = Foot Pounds (a measurement of torque)
WOT = Wide Open Throttle
ESP = Electronic Stability Program
CAI = Cold Air Intake
MOPAR = MOtor PARts or Chrysler Corporation Motor Parts Division
ABM antilock brake module
ASD auto shut down
ATC automatic temp control
BAS brake assist
BCM body control module
BTSI brake transmission shift interlock
CAB controller antilock brake
CAN controller area network (data bus)
CCN cabin compartment node (also known as MIC or cluster)
CHMSL center high mount stop lamp
DRL daytime running lamps
DDM driver door module
DTC diagnostic trouble code
EMI electro-magnetic interference
ESM electronic shifter module
ESP electronic stability program
EVIC electronic vehicle information center
FCM front control module
HCU hydraulic control unit
HFM hands-free module
HID high intensity discharge
HVAC heating ventilation air conditioning
HSD high side driver
HSM heated seat module
IOD ignition off draw
IPM integrated power module
LCD liquid crystal display
LED light emitting diode
LIN local interface network
LRSM light and rain sensor module
LSD low side driver
MIC mechanical instrument cluster
MTC manual temp control
MUX multiplex
NAG1 new automatic gearbox 1st generation
NGC next generation controller
OCM occupant classification module
ORC occupant restraint controller
PADL passenger airbag disable lamp
PCI programmable communication interface (data bus)
PCM powertrain control module
PDC power distribution center
PWM pulse width modulated
RFIS rear facing infant seat
RKE remote keyless entry
SCM steering column module
SDAR satellite digital audio receiver
SLA shift lever assembly
STPS seat track position sensor
TFT thin film transistor
TCM transmission control module
VIN vehicle information number
VTSS vehicle theft security system
WCM wireless control module
1Likes
