Results 1 to 6 of 6
    1982atm's Avatar
    1982atm is offline im str8
    Jan 2008
    indy
    wow this is loud
    so i got my zoomers cat back system yesterday.... i was so anxious to get it installed i took the day off.... so I'm at a little auto shop waiting when the installer comes in the lobby and says we have a problem,,,, they sent me the wrong kit. its the 2.25" kit for the 5.7. the shop couldn't weld the factory back up so I'm driving around with half a exhaust.... zoomers is being real helpful though they are next day shipping me the right kit tomorrow so i should have it by Saturday... but it is really loud right now.. the hole inside rattles around 2000 rpm
    MikeEast's Avatar
    Ducktown, Georgia
    Wonder what they cut that they couldn't un-cut?
    And there wasn't any cutting involved when my Zoomers went on if I'm remembering correctly.
    You'll appreciate the difference more now that you've run short straight pipes for a bit!
    Mike
    gsjoe's Avatar
    gsjoe is offline You talk'n ta me?
    Feb 2005
    st louis area
    They had to cut some inches behind the
    x-pipe for the zoomers to slip on. They could have put it back.
    Maybe they are not wanting to incure labor time.
    MSRT8
    Zoomers exaust, CFAH intake, Inertia ported with spartan max cam, predator w tune
    CSRT4
    Zoomers exaust, mopar s1, driver mod box, scan gauge
    1982atm's Avatar
    Jan 2008
    indy
    ya they cut 6" back from the cross member and they don't weld there that's why they didnt put the stock back on..... it was a brakes, alignment and tire shop.. not really a exhaust shop but i get a discount there they were going to install it for 60-90 bucks they said they had installed other bolt on cat backs so i figured it would be a good deal
    1982atm's Avatar
    Jan 2008
    indy
    well im supposed to get my new kit on sat.. cant wait to have it installed cause the mid pipe only is not cuttin it
    gsjoe's Avatar
    Feb 2005
    st louis area
    I really do like the Zoomers. The sound could not be better. At speed the cabin is quiet and we can talk at a whisper. At start it sounds like a HEMI should. Acceleration commands attention and WOT is nothing short of spectacular. Add a CAI and there is no need to tap the horn to pass
    The cabin sound then is true formula racing sound. It will raise goose bumps on you and scare the guy you are passing.
    I hope you like them as much as I like mine.
    MSRT8
    CSRT4
