Results 1 to 15 of 17
    risky's Avatar
    risky is offline LX Guru
    nj
    Why no spare on a srt?
    Is the pump in the back just to get enough air to get to the repair station? And the tirefit system what is that??
    Tomahawk cam, corsa, diablo, Bt catch can, Airhammer, 402 rockers , V-3, Eyelids, ID wheels ect. ect. ect.
    Ultimatecarman45's Avatar
    Ultimatecarman45 is offline otherwise known as UGM
    Timbuktu otherwise known as wyoming
    The pump in the back has GOoo in it to plug the hole to make it to a repair station and fills with air too.
    risky's Avatar
    nj
    Got to love this forum
    Ask a question get an answer in minutes----Do I need to keep the pump charged on a regular basis?
    36 chambers's Avatar
    36 chambers is offline Banned
    ON A HOLLYWOOD SET NEAR U!!!!
    pretty sure a 20 wont fit back there!!!!
    Husker's Avatar
    Husker is offline AG Strek
    Nebraska
    The pump plugs into the lighter..
    05 Red Inferno Magnum SXT-Traded
    05 Red Inferno Magnum R/T- Traded
    06 Silver 300C SRT8 RWHP 371 RWTQ 374
    Options I,II Sunroof,Side Curtain AirBags BIG HEMI
    bipto's Avatar
    New Hampshire
    Quote Originally Posted by risky View Post
    The pump runs off a cig lighter-type power outlet. Use of the Goo is optional... it can also be used as a (very) light-duty compressor. Comes in handy for replacing the air that you let out at the track...
    The Iron Mistress Galleries
    R.I.P. Dave...
    AZRC is offline Seeking Knowledge
    May 2005
    Chandler, AZ
    The No Spare on vehicles with big wheels seems to be the norm now. Most of the perfomance M-Benz & BMW's also axe the spare. There is no doubt they are saving some serious coin by deleting it.
    Note - Using the Slime (Goo) may damage the tire pressure sensor. Not sure if warrany would cover that even if you were under the 36K mileage. I just keep a tire repair kit in my MSRT.
    2006 MSRT8
    Twin Scoop Hood - functional Ram Air (with AiRaid CAI)
    Mopar Perf Exhaust (CORSA)
    LED Tails (FactorOne)
    Centric PosiQuiet Brake Pads
    Keir's Avatar
    Keir is offline LX Padiwan
    Thousand Oaks, Ca
    The replacement goo canister is like $70.00, I keep a tire plug kit in my car it's cheap $15-20 with a bunch of plugs and won't mess up the sensors. I use the compressor part to top of the tire after repairing the tire.
    Husker's Avatar
    Nebraska
    Quote Originally Posted by AZRC View Post
    Plus the tire guys really don't like the goo...at least the guy I go..he said to tell him BEFORE he touches the tire if I used the goo
    glhs837 is offline Power With Control
    Very Southern Maryland
    Just a few notes.
    1. The goo, is NOT slime, which is a trademarked thing all its own. As far as I can tell from my research, the goo is actually %100 latex, and I've yet to find a case of it harming the sensors. I know mine was fine, as have been all the other cases I've found, maybe 5-8 of them.
    2. Apparently, the Tirefit is an adaptation of a system that Mercedes had Continental develop for them back when they first started selling AMGs with no spare.
    3. I balked at spending $80 for a replacement goo my own self, and so went into this. This thread has my findings.
    http://www.chargerforums.com/forums/...hlight=Tirefit
    LIME 108's Avatar
    LIME 108 is offline LIME 108
    Feb 2007
    Gilbert, Arizona
    Talking SRT "Factory" Tires are Goodyear F1, RunFlats
    The stock tires, are Goodyear F1 RunFlats, that is why only a pump. No need to change to a spare, you can drive runflats as you would a donut spare,
    AFTER you install the Goo & Air up.
    HOWEVER if you do not have factory tires, then your screwed, UNLESS the replacement tires are also RunFlats.
    Jeff East - Gilbert, AZ.
    2007 Sublime Daytona #0108, "Margarita
    2012 Charger R/T Road & Track w/Track pack, we will call this one "Likrish"
    Hey George Soros, will you do us all a favor and Die Soon!
    No, only the Jeep SRT comes with runflats, the other SRT-8s do NOT. Niether the F1s, nor the RSAs are runflats.
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by glhs837 View Post
    x2.....
    risky's Avatar
    nj
    Where do I get a repair kit??
    Pep boys??
    wantit is offline LX Newbie
    Oct 2005
    Long Island, New York
    tirefit? you mean tire$**t! mine is in the garage since day one. I have a combination air compressor/ jump starter, AND a full size spare wheel & tire in the trunk. I ain't gonna get stuck with a flat no where, no how!!!!!!!!
