Results 1 to 15 of 25
    legmaker72's Avatar
    legmaker72 is offline Saving the world one leg at a time!
    May 2005
    Jacksonville, Florida
    Question TSB 09-011-06 Oil Cooler Jets...anyone look into this?
    After I've been driving a bit, I notice when I stop a whining which sounds like a belt or a "fly buzzing kind of sound"...if I give it some gas it will dissapear for a moment and then reapear...
    I read this tsb and it sounds like it to me.
    Not much else but a change in oil viscosity....
    It still happens here now during the winter....but it's not a REAL winter here in Jax...so I'm not sure if I should change the viscosity for summer as a permanent change.
    Your thoughts ol' knowledged ones!
    Take care,
    Christopher
    ________ ________
    "I complained to God that I had no shoes, until I met a man with no legs"
    fnkychkn's Avatar
    greasy cardboard box
    the TSB states that the whine typically happens in engines operated in ambient temps above 50*F. i think you're pretty safe with the 15W50 year round.
    mjc1241 is offline LX Newbie
    Jun 2006
    I live in Atlanta. I am taking the car in on Wednesday for this and the TCM TSB. I will know more that evening.
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    I know its not recommended, but you *can* run 1/2 0W40 1/2 15W50 with no problems coming from the oil.
    It would bump the viscosity just a little bit when idling, but not cause TOO big of a change, allowing for quick oil movement on cold-starts.
    jim383 is offline O7 SRT-8 GC JEEP
    CA
    Heres The Number You Check On The Passenger Side Of The Water Pump Housing Just Above The Thermastat Housing.its On A Big White Label.here Is The Nuber Tnxe6026620001 Or Less.which Means All Engines Built On Jan 26 06 Or B4 You Got The Problem. Tnxe6-0266-20001 The 0266 Mean The Engine Was Built On The 26 Day In 06. Mine Was Built On The 42 Day Of 06 So Im Ok.
    Buckola is offline LX Newbie
    ontario canada
    Any one have plans of going to the track for a real life comparison?
    bellman25's Avatar
    bellman25 is online now LX'er
    Jan 2006
    MD
    not trying to hijack the thread, but is there any danger with this noise condition? is it anything more than annoying? if you can run 15-50 oil, 10-40 should be ok then too right? any input please!!!
    11' Charger R/T MAX
    '08 Cherokee SRT8- TRADED..
    '06 Magnum Srt8- TRADED..
    '85 Mercury Capri 5.0
    legmaker72's Avatar
    May 2005
    The TSB states that there is no risk with the noise,...so it's just annoying I guess. I don't like it...Makes the car sound bad, especially when sitting at a light.
    My 06 was built late in 05, so I guess that is why I have the problem? Does this mean that the later model MSRT's have a different viscosity of oil or do they also have the 0W40? If so, what did they do to fix the problem?
    Take care,
    Christopher
    ________ ________
    fnkychkn's Avatar
    Quote Originally Posted by legmaker72 View Post
    i believe they changed the design of the oil squirters.
    maherm is offline LX Newbie
    KUWAIT
    Angry
    All of the CSRT8s here in KUWAIT whine and all built after feb,2006
    Mineral Grey CSRT-8
    lafrad's Avatar
    Feb 2004
    Muskego, WI
    I am sure, in Kuwait, you could use the 15W50 and have NO problems whatsoever.
    Husker's Avatar
    Husker is offline AG Strek
    Nebraska
    Quote Originally Posted by bellman25 View Post
    The SRT guys have stated TWO specific weights of oil to use, the
    0w-40 and the 15w-50. That's it..if you want to use something else, you are risking the warranty..not woth it if you ask me. Besides the SRT guys use specific oils due to the tests they run..
    05 Red Inferno Magnum SXT-Traded
    05 Red Inferno Magnum R/T- Traded
    06 Silver 300C SRT8 RWHP 371 RWTQ 374
    Options I,II Sunroof,Side Curtain AirBags BIG HEMI
    My Hemi's Avatar
    My Hemi is offline LX Homosexual
    Jan 2005
    New Jersey
    Im confused here is my number on the white label.... TNXE6111620210 Is mine after the problem date should i use the 15w 50 in the summer months????
    2006 MSRT-8 ...GONE....
    rsfdoc is offline stealth shifthammer SN-001
    Dec 2005
    Florida
    My understanding and memory(you are risking a lot here if you listen to me) is that the whine is caused by harmonics produced by the "oil squirters" in the upper part of the 6.1. It is not supposed to be a mechanical or longevity problem but simply an undesirable noise. They have corrected the "noise" by simply changing the angle of the "squirters" for the later 06 and 07 models.
    Buck70 is offline LX Newbie
    Feb 2006
    KC KS
    Quote Originally Posted by jim383 View Post
    Does anyone have an actual part number for the revised oil squirters?
    I just tore down my shortblock and noticed the check valve in them, but
    I dont have a build date for that SB. Also should be a surplus of squirters
    out there from the stroker guys that aren't putting them back in due to
    clearance issues.
    DB
