http://cgi.ebay.com/ebaymotors/Charg...QQcmdZViewItem
Have any of y'all seen this or tried it. I didn't do a search so if this has been beat to death just say the word!
06' MSRT-8
SR*S/Magnaflow COPY catback with Muffler delete and it sounds GREAT!
Tranny_Nanny Good bye spirited driving you will be missed. RIP
05'QCSRT-10
Roe 3.0L Whipple, Comp Coupe Cam, VECIII, MBRP 4" Single exhaust, Caltrac's, 2000 watt stereo and NOTRANNY-NANNY!
Interesting find... I bet it only takes off the first stage though and not the one where you have to hold the button for 6-8 seconds.
someone on here did a clever write up on the bypass similar to the gsm mod but cut the wire under the armrest portion of the console instead of up front in the engine bay. It's the same wire, just clipped right at the module instead of at the wiring harness.
Would you guys want a module that did the "6 sec button press" for you on startup? I could build 'em without much trouble.
I'm down....as long as you can switch it back when it's raining.
Brains, you do it and i'll buy it! If you build it, we will buy.!
06' MSRT-8
05'QCSRT-10
I'm not in the electronics fab biz, so I don't see myself mass producing 'em any time soon. But if I have extra time I don't mind throwing a few together for folks.
Ike, just noticed you're in Katy too, surprised I haven't run into you yet![]()
first time i have read this. what happens if you hold the esp button for 6 seconds?
Okay, I built one and the proto is sitting here on the bench. Who feels comfortable pulling apart their dash and testing? What's the lxforums policy for an individual building and selling little stuff like this?
I built the module so its configurable without adding any extra buttons or switches, and has audible feedback so you know what it is setup to do. Its programmed via the regular ESP button. Current software works like this:
1. Turn the key ON (don't have to start the car).
2. Press and release the ESP button three times within 3 seconds -- unit will beep 5 times in rapid succession to indicate you're in program mode.
3. Press the ESP button 1, 2, or 3 times to indicate which mode you want the ESP system in after you start the car: 1 = ESP ON, 2 = ESP off (normal), 3 = ESP off (completely)
4. Wait 5 seconds and the unit will beep back to you the mode number (ie. 1, 2 or 3 beeps) and exit programming mode.
5. Cycle the key and voila
Once programmed, the module will wait a few seconds after powering up (for the car to be started) and then mimic the button press you programmed (ie. none, short press, long press). You can of course press the button at any time like you normal would to switch modes.
Hey Brains - would this work on the standard esp on regular R/T`s?
Scott
"DETONATOR"
Sidewinder numbers
1/8 8.45@82.90
1/4 13.14@107
Certified AAC Houston Installer
Brains... I gotta take my dash apart anyways.. I'll help test! If it would work on a 5.7L
05 "Shagwagon" R/T
Go USF Bulls!
Hemi Registry #000514
The 5.7 can't use the "long press" option. It'd do the same as the short press, unfortunately. This only mimics your finger on the button, it really doesn't do anything magical. Just a convenience item.
I'll get one put into a box here once I can break away and get to the local electronics store for the parts. Keep ya posted, and thanks for the offer to test, Todd.
Went through the proto again last night checking for bugs, and it works exactly like it should -- on the bench.How hard is it to pull the dash apart and get to the ESP button so I can put it in the car?
Since its programmable, it will work on all cars with an ESP button. It also passes through the normal button presses, so if you program it to disable ESP on startup and wifey wants to drive the car, she can just punch the button and turn the system back on. It takes less than 15 seconds to program your choice, so you could always program it to the stock setting if you know someone else will be driving the car next.
Can't think of any other features to code into the software right now, so unless you guys can come up with ideas I'm going to call it "done."
