I've got the clunks GDmit and I'm not happy. I took her in Monday, said sway end links and changed them out. Drive home feeling good till my driveway and clunk or rather clink clink. Same sound. What's next? Any ideas? I'm thinking tie rod but surely that woulda been the first they checked. Help. I hate the clunks.
Gettin' Lucky in Kentucky...Maysville, KY
No sir, it's more at real slow speeds going over abnormal pavement. Sounds like a 'clink' but it's when turning.
Upper ball joints. Mine only made noise when turning.
Jay
2011 Dodge Challenger R/T Classic - Redline 3-Coat Pearl, 6-speed2005 Dodge Magnum RT-Can you say...HEMI?2004 Chrysler Pacifica AWD-Everything but the kitchen sink.1989 WS6/L98 Trans Am-Got Torque?
ive had this issue since over a year
replaced some parts
sound still comes
i get a big tak sound once only when i turn right in the morning
but the clunk still there over bad uneven roads
Did you replace the sway bar bushing? or the links. Links are usually ok on these cars. Bushings are junk though. cheap fix to. on 12 dollars at the dealer.. and it's a DIY project..
Happen to me! It's definitely the suspension. Every bolt on your suspension needa to be inspected and/or tightened. They tightened just one bolt about a 1/4inch and the sound went away for good. Go to a shop n have them tighten up everything in your front sway bars and control arms.
HEMI ORANGE '09 Dodge Challenger SRT8
NEW BUILD:
New build: 3.6L kenne bell, 148mm throttle body, Inertia 392 forged motor,Inertia big boost heads, SHR 1000hp transmission, inertia blower cam, 1400 DSS driveshaft, Fore dual pump fuel system, BB Dominator TQ converter, SP sway bars and lowering springs, OBX Long tube headers, Bassani midpipes, Flowmaster mufflers
DYNO: 731rwhp/635rwtq 15psi 93oct...Race tune: 875rwhp 17psi e85 gas, Daily Driver Tune: 830 rwhp 17psi e85 gas
https://www.youtube.com/watch?v=Ej1w...e_gdata_player
Is this the sound most of you are receiving?its hard to hear it but it is there for sure just crank up your volume
Sent from my DROID RAZR using Tapatalk 2
Front end "Klunk" can be any (or some...or all) of the following:
-Tie Rod Ends
-Ball Joints
-Sway Bay End Links
-Tension Strut bushings
-Lower control Arm Bushings
-Upper Control Arm Bushings
The Rubber bushings in the tension struts and control arms cars have a tendency to tear.....it is a common issue
I had the "klunk" in my Magnum and it was the Tension Strut Bushings..........I currently have to replace the Tension struts and lower control ams in my SRT8 Charger as I have the "Klunk" and the bushings are showing signs of tearing.
This is an example of what to look for:
HEMI Registry #1575.......PB - 13.390 @ 106.67 Mph.
Proud Member of The WTFDTSG Club.........
ball joints on mine, had to replace two of the control arms.
