Results 1 to 8 of 8
    Q8.
    Q8. is offline LX Newbie
    May 2006
    stock Intake Manifold porting help
    i just removed the stock air box to take a closer look at the TB then i pushed the butterfly with my finger to look inside the intake manifold WOW the falang from the intake manifold was slightly smaller than the TB falange. you can feel it with your finger it has ruf edges all around and on one spot rite at the bottom there is an extra bump at least 2-3 mm of metal that i can just dremel away...but i wanted to know has anyone noticed this and did anyone try to even both surfeses out...
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    Yeah. I did notice that. I dont think anyone has done this but it wont hurt anything either. I dont expect to see much of a noticeable change in engine power output..
    BE sure to remove the manifold before doing that!
    Take pictures too!
    And the dead shall walk
    Q8.
    May 2006
    i will take pictures when i do this it is too dam hot to do it now but i will do it for sure ....you dont even have to remove the manifold..
    best way to do it is before taking off the TB get a black marker pen and just outline where the manifold sticks out over the TB hole..then remove TB stick couple rags in there and start to grind then vacume shavings and reinstall TB.. thats it
    Q8.
    May 2006
    i did the same thing on my 5.9 durango and the throttle responce was very noticible
    CVP33's Avatar
    CVP33 is online now Moose & Squirrel did what?
    Feb 2006
    Oak Ridge, NC
    I have no experience with Mopar TB's but LS1, LS6 and LS2 TB's usually get between 5 and 7 hp from this mod. I don't know if the juice is worth the squeeze on this one. Then again every pony counts. This equates to a 1.17% increase in horsepower.
    QUICKSilver
    2006 300C SRT-8 Option I, II, Kicker, Sunroof, DVD
    Dyno - 625rwhp 558rwtq (9.5psi)
    1/4 Mile 10.956 @ 127.81 mph (10's @ Rockingham damnit!)
    DTP installed ProCharger, HHP/BES forged 6.1, HHP Stage IV cam, AJ tuned, Meister Oil Cooler, Magnaflow mid-pipes, Billy Boat Exhaust, SHR Trans, BB Flexplate, Edge converter, '09 LSD Getrag, Hotchkis Sways, Speedlogix RSTB, BCR coilovers, 3gC Tins, BT everything they make!
    MagnumFreak's Avatar
    MagnumFreak is offline Chasing Dreams
    Jun 2004
    Evans, GA
    Although the PCM will notice the increased airflow through its Mass airflow calculation it will not know what to do with it.
    2005 Dodge Magnum R/T
    -Martin Luther King, Jr.
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by MagnumFreak
    Are you sure that adaptive learning will not recognize and adjust accordingly. If not how do you explain the effect the larger/better flowing CIA's had at GIFO. I may be wrong but something has to give. I think enlarging the throttle body and or modifing will have some advantages to a motor that has the additional breathing capicity on the back side.
    Q8.
    May 2006
    if true then how did the guys with ported heads get 40-60HP
    this is like a 1-2 hour job you are only cleaning up some imperfections with the factory mass produced manifold..
    what you are doing is making it smoother for the air to pass after the TB into the intake ports.
    im going to do it next week and just for fun im going to the dyno tomorow and then ill go again after i do this mod...
    hey maher do you want to meet at the dyno tomorow lets see what your srt with stock exhust and volant can do ????and my srt with high flow cats and stock airbox can do....
