Results 1 to 15 of 19
    dbarwick is offline LX Newbie
    Feb 2007
    Charlotte, NC
    SRT8 Brakes replaced for free Chrysler Bulletin!
    My brakes began sqealing at 5k miles (06)
    I was taking my vehicle in to get my pcm reflashed to stop that terrible shift hesitation (btw-Much better now!). Anyways, they said there is a bulletin that all pads from the 06 SRT8 are to be replaced if anyone comes in stating this issue. They replaced them for free giving me new pads (these arnt cheap $600).
    Just an FYI!
    Props to Keffer Dodge In Charlotte, NC Chris O is the service manager.
    da BoMM's Avatar
    da BoMM is offline Conspicuous Combustion . . .
    Spring, TEXAS
    Quote Originally Posted by dbarwick View Post
    Just an FYI!
    WHAT ABOUT '07's ????
    6.1L HEMI #622 '07 TorRed MSRT8 1/165= TORRED >< 6.1L HEMI '10 Silver Jeep GC SRT8=4X4JET
    MSRT8 owners http://www.lxforums.com/board/groups/magnum+srt-8+owners/
    Maggie is offline LX Newbie
    Forked River, NJ
    Quote Originally Posted by da BoMM View Post
    It was a TSB for the rotors (changing to slotted), which your 07 came with.
    Not aware of anything for the pads.
    Cheers!
    Chris
    07 Magnum SRT8, Steel Blue, Options I,II,III, Roofrack.
    Super T's Avatar
    Aurora, IL
    Yeah, if you find something for the pads, PLEASE let us know!!!!
    Jaak's Avatar
    Jaak is offline MOPAR. The only way to BEE.
    May 2005
    Oakville, ON
    Yeah, there's both and I've had both done.
    "Hey, my brakes are squealing like a symphony of cats in pain, what can you do about it?"
    "Front or Rear?"
    "Yes."
    Then a couple of months later...
    "Damn, these discs are scored, WTF is with that?"
    "We'll put on the slotted rotors sir...."
    Well, OK, that last part was a lie, 'cause they don't ever call me "Sir" unless I'm doing something I'm not supposed to be doing. "Sir. Sir.... SIR! WOULD YOU MIND NOT HITTING THE BALLS OVER THE FENCE SIR!"
    Super Bee #0427 of 1000 with USW Forged Wheels
    Mopar CAI, Corsa Exhaust, Diablo canned tune, Drag Radials, Skinnies
    12.217 @ 117 mph
    Feb 2007
    Charlotte, NC
    Should I have got my rotors slotted as well too? grr. They didnt do that
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Yep, if there is any hiint of grooviing on the inside or outside of any rotor, you get 4 new ones with slots
    I "hinted" to my dealer and they happily changed them
    Dan SS2471 is offline LX Newbie
    New Jersey
    It's cool that he replaced the pads without being solicited but the TSB is mainly to cover the rotors and replace them with slotted ones.
    Although the new pads supposedly cut down on the brake dust a bit, it's still ridiculous. If the dust drives you nuts, go with a set of C-Teks or Posi-quiet. Dave Zeckhausen stocks them.
    Here's the TSB:
    NUMBER:
    05-006-06
    GROUP:
    Brakes
    DATE:
    Aug. 2, 2006
    This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system,
    or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of DaimlerChrysler Corporation.
    SUBJECT:
    Front And/Or Rear Brake Rotors Grooved/Scored
    OVERVIEW:
    This bulletin involves installing slotted brake rotors.
    MODELS:
    2005 - 2006 (LX) SRT8/Charger, SRT8/Magnum, SRT8/300C
    SYMPTOM/CONDITION:
    Front and/or rear brake rotors may appear grooved or scored prematurely.
    DIAGNOSIS:
    Inspect the brake rotors. If the rotors show premature grooving or scoring, perform the
    Repair Procedure.
    PARTS REQUIRED:
    Qty. Part No. Description
    2 05290537AB Rotor, Slotted Front
    2 05290538AB Rotor, Slotted Rear
    REPAIR PROCEDURE:
    Using the procedures outlined in TechCONNECT: SERVICE INFO tab /5 -
    Brakes/Hydraulic replace the front and rear brake rotors with the slotted rotors listed in the
    Parts Required section. Inspect the brake pads and replace the pads as necessary.
    NOTE: If premature grooving or scoring is present on any rotor, slotted rotors must
    be installed in the front and rear.
    POLICY:
    Reimbursable within the provisions of the warranty.
    TIME ALLOWANCE:
    Labor Operation No: Description Amount
    05-21-10-96 Replace Rotors, Front and Rear (B) 1.1 Hrs.
    NUMBER:
    05-006-06
    GROUP:
    Brakes
    DATE:
    Aug. 2, 2006
    FAILURE CODE:
    ZZ Service Action
    05-006-06 -2-
    Jaak's Avatar
    May 2005
    Oakville, ON
    Uh, THE TSB?
    You mean that TSB... There's Two Dan. One for the pads and one for the rotors.
    Here's the beginning of the other one.
    NUMBER: 05-005-05
    GROUP: Brakes
    DATE: October 4, 2005
    THIS BULLETIN IS BEING PROVIDED IN ADVANCE. DO NOT ORDER PARTS OR
    PERFORM ANY ACTIONS RELATED TO THIS BULLETIN UNTIL DECEMBER 15,
    2005.
    SUBJECT:
    Front And/Or Rear Brakes Squeal When Braking
    OVERVIEW:
    This bulletin involves replacing the front and/or rear brake pads
    MODELS:
    2005 - 2006 (LX) 300C SRT8/Charger SRT8/Magnum SRT8
    SYMPTOM/CONDITION:
    Front and/or rear brakes squeal when braking, most noticeable with light brake pedal
    application.
    DIAGNOSIS:
    If the vehicle operator describes the Symptom/Condition perform the Repair Procedure.
    NOTE: Replacing the brake pads will NOT reduce brake dust or minor rotor
    grooving.
    Slim's Avatar
    Slim is offline The King Nitwit!
    Jan 2006
    Marysville, WA
    I had my rotors replaced after just 900 miles on my car. Scoring on the rotors had already showed up. After they replaced the rotors with the slotted ones they started squealing. I let it go for a while but finally I realized that it just was not going away. The week before the Spring Festival I took it in and they put new pads on all 4 corners. I traveled over 2700 miles to Irvine and back and never heard them squeal once!!!!!!
    Islamic terrorists are like King Salmon,
    Life is good until the Seals show up!
    His: 06 Magnum SRT <----Sold
    Now: 73 440 Plymouth Duster
    Hers: 08 Charger R/T
    New Jersey
    Quote Originally Posted by jaak View Post
    Uh, THE TSB?
    NUMBER: 05-005-05
    GROUP: Brakes
    2005.
    SUBJECT:
    OVERVIEW:
    MODELS:
    SYMPTOM/CONDITION:
    application.
    DIAGNOSIS:
    grooving.
    Ah. Good catch.
    Although....I wouldn't even bother with that one.
    Thanks for clarifying!
    Dan
    Jaak's Avatar
    May 2005
    Oakville, ON
    No problem Dan. I agree the slotted rotors is the best upgrade!
    Free set of pads? Put your old ones back in, go complain, get a free new set, then put the aftermarket ones back in.
    My updated pads are sitting in a box, just in case... Especially when you consider what Mopar charges for them!
    marmaduke's Avatar
    marmaduke is offline LX Padiwan
    Feb 2006
    Toronto
    I just had the slotted rotors and pads done on my 06 CSRT8 under the TSB's...
    The team at Eastway knows what the LX platform and customer service is all about!!! Highly recommended!
    I made the mistake of going to some local dealerships and they did not have a clue... I will not make that mistake again... I had one try to tell me the 300 does not come with a 6.1 Hemi and that an oil change should never cost me more than $40.00... yeah right!
    Breaks - Seems that I should not expect to much of an improvement on the brake dust issue? Still early to tell...
    What is recommended for little to no dust? Is this possible?
    Thanks!
    2006 300CSRT8 - 2006 MSRT8 - 2006 GCSRT8
    marmaduke's Avatar
    Feb 2006
    Toronto
    JAAK, what pads do you have? Dust? Where? etc....
    Cheers!
    Jaak's Avatar
    May 2005
    Oakville, ON
    That's why I went to Ceramic. Well that and I've been happy with them in the past. If you're not in a rush, you can see what mine look like when I change my wheels in a few weeks. I'll take pictures.
    The Ceramic dusts like any pad will, but it doesn't stick as much and it's a lighter colour so what little there is, is not so noticeable.
    Too funny I post this, and then see your post asking...
    Satisfied Ceramics. I did a thread on them somewhere in here.
