Results 1 to 8 of 8
    Largo, FL
    Spark Plug Deal (OEM replacements)
    For those who aren't needing to upgrade and willing to try the Champion version of the OEM SRT8 plugs... you can get a helluva deal right now.
    Rockauto has the Champion 7570 (RC12PYP) for $4.78 per plug. Then go to www.Championrebate.com and get a $2 rebate.
    These are double platinum tipped, resistored. Heat range is 12, which I guess is supposed to be the same as NGK 5... but who knows. This last part is why I may not go for this deal, because I don't know how the heat ranges between the two companies map out.
    But $45 for a full set of 16 platinum plugs is tempting...
    NYC POPPA is offline LX Padiwan
    Oct 2010
    Queens, NY
    any info on these? just picked them up from pep boy for 3.99 a plug. just a lil nervous to put them in cause they were so inexpensive..... and it doesnt say the gap anywhere on the box.... any help is appreciated
    370 cubic inches of LOVE, HID Headlights and Fog Lights, light window tint, Billy Boat Performance exhaust, Mopar Cai, 180 Jett Thermostat, Razors Edge strut tower brace, Suspension Techniques sway bars, Custom Predator 93 octane CAI Tune, AAC V2 Blue LED scanners in hood scoop and front grill
    NEWSCHOOLMUSCLE.COM
    Largo, FL
    Well... the NGK website has a heat range map which says the Champion 11 and 12 is equivalent to NGK 5.
    Google search doesn't show many reviews but some guy over on DodgeForum.com seems to like them.
    I think you'll be fine. Let me know what you think of them.
    I don't remmeber if the NGK box had gap information either but the NGK p/n itself is for a specific gap. Maybe Champion p/n's are the same way and they think it's not necessary to label the box with gap info.
    Largo, FL
    Gap should be about 48 mils (0.048") if you wanna double check them. My NGK's out of the box were 48 to 50 mils.
    Unless you are way way off, I would not recommend trying to gap them yourself.
    Oct 2010
    Queens, NY
    yeah i heard you are not supposed to gap platinum plugs so i dont wanna mess with them....guess ill just have to put them in and see......
    Largo, FL
    Thats what I heard too, plus the NGK instructions said not to.
    Oct 2010
    Queens, NY
    Oct 2010
    Queens, NY
    Well installed them. So far so good. No problems so I guess that's good lol
