Used both, and there's still no direct evidence that the Powerbond units are the issue. Has anyone done proper analysis on the fractures?
What journal is that Scott?
---VIPER--VENOM--RED--------------------------Click-- Hemissary--to read complete story at--CarDomain----
agreed
I agree there is no direct evidence but the fact is they all had the powerbond. As for a proper analysis? Who has the time.money for that? I sure dont. All I can say is that any motor that is going to make anytype of serious power I will no longer install a power bond.
And to answer your question that pic is in the same spot as this.
Ok I'm here with aquestion..
I have a high power stereo. Which is connected to a separate stereo battery, which is connected to car battery which is a yellow top. Also connected to the yellow top is a Air Ride system. I also have HID's and Halos, I still have the stock Alternator and my car has 100k miles on it.
I want to get a pulley but am concern that my old ALT might not be able to handle it..
If fact at car shows if I run my stereo/dvd and 5 monitors after a while car has problems starting up (turning over) and thats with a yellow top..
also my current performance set up is Slidewinder cam and street heads both from franks.. Both 4 yrs old now. and I have mopar long tubes and Borla 125 cat back.
..The Minotaur Is On The Rise
Check out my Stock to Rock pictures
http://www.jamcarclub.com/showthread.php?p=8#post8
If your alternator is functioning properly now...a pulley is not going to alter that...
Have there been any failures with OEM crank shafts and the SLP pulley?
Anyone care to throw this into the mx?
Summit Bracket Racer SFI Harmonic Damper 05-08 300, Charger, Magnum, Challenger, Jeep 5.7L
Just a grocery getter!
Wrong thread really, but I'll elaborate. Dimming headlights can be from other failures/partial failures, for example a battery not retaining a charge.
More likely...those who are experiencing dimming or flickering lights could also have likely pointed out...it's happening at the same beat as the music they are playing. As in the power demands of the stereo, or any other electrical system over-and-above is taxing the alternator's ability to keep up, and as result battery voltage is diminishing. A marginal battery (little charge-acceptance) with the OEM sound system could also(!) produce fluctuations.
Keep in mind once the vehicle is running the battery plays a very minor role. System voltage and current control is one of the PCM's jobs, which it does very efficiently (eg; controlling alternator duty cycle) as long as it has not been tasked with aftermarket systems (stereos, lights, TV's, drive motors for pneumatics, etc). It is wrong for anyone to assume "the system" can handle these extra electrical loads. Of course there is a margin...but in most cases folks are requesting, and expecting, way too much from it.
A properly (keyword) operating electrical system will not tax the charging system simply because an underdrive pulley was installed. Any additional electrical loads...all bets are off even with the OEM dampner in-play...
Ill join the high jacking for a minute as well :-) When I breifly ran the SLP I noticed dimming lights and a voltage drop at idle as per my evic.. I dont run a fancy radio neon lights or airbags.. I just figured that the Alternator was designed for a certain Rpm to charge properly and I wasnt meeting that RPM.. SO I just lived with it..
'11 Mustang GT 5.0...Kona Blue...6spd Manual...Couple power mods...
Well I will be the first to admit that I am NOT the sharpest tool in the shed.
You of all people Scott should know that.. LOL That is why I asked the question
I currently run a large stereo, Halos, and Air Ride. At this time I have no dimming issues at all.
But I heard stores about UD Pulley making your ALT work harder and caused some issues.
I am planning to add a UD Pulley and wanted to confirm if this was true or just a myth.
I have even heard that upgrading to a higher amp ALT would be a good idea..
So being I have no issues now I will not have any issues when I install a UD Pulley
Thank you for your input....
I'm pretty blunt too :^)
For the record my 05' has fluctuating headlights since it was new...just ever so slightly but detectable to my old eyes. After installing HIR's (more current consumption) those fluctuations did not get worse (or better). For the record, HID's usually reduce current consumption over OEM halogens...
