Results 1 to 9 of 9
Like Tree2Likes
  • 2 Post By 1FST4DR
Thread: OK, Rear Brakes replaced@20K..but tech says I have a problem....
    zoomzoom1's Avatar
    zoomzoom1 is offline LX Padiwan
    Feb 2009
    Roanoke,Va
    Question OK, Rear Brakes replaced@20K..but tech says I have a problem....
    I have been getting the ABS double chime..in the chime warning system...but it then went away..(scrugs)...but just got back from visiting Brent at DTP..and he did a check on my tune..(3 yrs old..and not even a hic-up)...took car in for inspection..found out I need rear pads...NOT front..but rear....?????...I told my tech about the ABS chime I had for 2 months, he did a check, first with the starscan...nothing in memory..nothing in the ABS Module, he then hooked up the starmobile..and off we went.....nothing.....readings were normal..(he loves the tune in it)..but says that the rears shouldn't wear out, I still have 60% left on the front....He asked me to post it here and see if anyone else has seen this....what you guys think...somethin' ain't right....
    2006 TB Daytona 3033-4000
    Arrington Heads,Spartan Cam, Mopar CAI,Mopar Long Tubes, Borla Cat-Bac, Dyno-Tuned by Brent @DTP Racing..360rwhp 390rwtqe
    2006 Inferno Red SRT8
    Mods: to many to list
    1FST4DR's Avatar
    1FST4DR is online now I just dont get it...
    Ft Laud.....
    Do any burn outs lately?
    NOTPAID4's Avatar
    NOTPAID4 is online now "OLD GEEZERS LOVE CARS TOO!!!"
    Feb 2008
    N. of Charlotte, N.C.
    Are YOU still on the stock (non vented rotors)? On my 06 Mag SRT I had the first set of pads replaced at 7,000 miles and at 8,000 miles they were squealing like a school bus. Finally after many arguements with the dealer they finally replaced all of mine to 2010 style slotted rotors and all new pads again. I have had NO problems since that time; currently at 11,300 miles.
    Old Geezers LOVE cars too!
    HEMI registry #864
    My Rides:
    2006 Black Magnum SRT (SHADOW)
    2005 Red Magnum R/T (LUCKY)
    2005 Blue Magnum R/T (BLUE)
    2006 Silver SuperCharged 300 SRT (643HP)
    Jim
    zoomzoom1's Avatar
    Feb 2009
    Roanoke,Va
    Quote Originally Posted by 1FST4DR View Post
    Not lately......well maybe some, but not many....
    zoomzoom1's Avatar
    Feb 2009
    Roanoke,Va
    Quote Originally Posted by NOTPAID4 View Post
    I had the TSB done when the car was new...slotted.....
    1FST4DR's Avatar
    Ft Laud.....
    Quote Originally Posted by zoomzoom1 View Post
    That where your rear brakes went
    silver00 is offline LoudSRT8
    Apr 2009
    Redmond, WA
    Do you live in a wet climate? I had to replace my rear pads at 17k because the Traction and Stability control systems actuate the brakes to modulate torque when there is wheel slippage, which wears the brakes prematurely. It rains all the time in the Seattle area so I'm always sliding around. After I changed them I started turning off stage one of the traction control most of the time (it still jumps in if you get unexpectedly sideways unless you're stomping on it). That solved my rear-brake wear problem. My guess is you have the same thing going on.
    zoomzoom1's Avatar
    Feb 2009
    Roanoke,Va
    Quote Originally Posted by silver00 View Post
    I do have the issue of tire spin sometimes......well...I can't help it!...To dam fun....But not many burnouts..tires cost to much...so first stage of ESP off...sounds good to me....
    Camsdad's Avatar
    Camsdad is offline SRT-8 Rookie
    Sep 2007
    It might have to do with ESP. Hal applies the rear brakes for stability and traction. At least that's what I was told .
