Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By reSRTrection
Thread: NGK or Denso?
    CEk's Avatar
    CEk
    CEk is offline LX Padiwan
    Sep 2010
    Sweden
    NGK or Denso?
    So preparing for a little maintenance for my MSRT8. Getting the Bosch long life filter for the oil change and then I got to the spark plugs. Which one should I go for? The NGK iridium or the Denso iridium? What's the actual difference between them - really?
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    I had Denso iridiums in my 5.7. When I changed them out, I was surprised to find that the electrodes were completely gone. After talking to my tuner guy, and knowing that I was spraying nitrous he advised that I stick with copper plugs. Copper has the fattest spark according to him. I would probably stick with what Chrysler put in your 6.1 from the factory. NGK or Champion. I'm not sure what advantage that iridium will have. BTW, I dynoed my car with old worn Champion plugs that came from the factory, then put in the iridiums, no difference.
    SuperFrawgie1361's Avatar
    SuperFrawgie1361 is online now formally 2intenz
    Nov 2008
    Panama City, Florida
    I run the Champion iridiums, have about 63k on them, seem to be a good plug, Chrysler recommends to change the oem copper plugs every 30k.... I need to check them, I think I have one or two bad right now cause I have a slight miss....as for power gain Like Formerice said probably no difference..... champion has been a OEM chrysler plug forever so thats why i went with them
    Hemi Registry #1348 SuperFrawgie 1361
    Largo, FL
    Bull****. The OEM Iridiums are not scheduled for 30k mile maintenance, its 90k miles.
    I think the NGK's will serve you well.
    reSRTrection's Avatar
    reSRTrection is online now Mopar or no car
    Dec 2009
    Incirlik, Turkey
    the only reason champion has been a factory plug for mopar is there cheap. and cheap they are. ive had two motors get destroyed by champions and have seen a few more. personally id recommend running NGK in everything from your lawn mower to the car. use your 16 factory champions as depth finders when you go fishing. denso iridium's are great for two strokes. iridium's help with burning the fuel cleaner and more efficient then a copper plug. in turn youll have smoother idle and better throttle response but really no power increase. there worth the money id like to think.
    Knight likes this.
    2006 Chrysler 300 SRT8 - SRT MAX+ cam by inertia, CAi by arrington, 3200 stall by Paramount, Doug thorley tri-y long tubes, diablo trinity, Billet tech catch can, z mount, thermostat housing, shifter bezel, 3G Customs BB fire wall cover, Speedlogix/REM 4 point rear shock tower brace, straight pipes with "chevy" tips, powder coated rims, gorilla black lugs. Vossen CV3's
    Got cam? http://www.youtube.com/watch?v=hWDo_MhvJWA&feature=plcp
    TwinCommander's Avatar
    TwinCommander is offline Mutliple Mopar Owner
    Aug 2008
    Hillsboro, OR
    im running NGK iridiums. i had to regap them after about 25 - 30k miles of use, but no other issues.
    2006 Bright Silver Magnum SRT-8
    Air Hammer CAI - AirAid TB Spacer - Diablotoona Equiped
    NGK Iridium Plugs - Magnaflow 3 inch pipes
    BT Catch Can - LED signal lights
    Pioneer Avic Z110BT Hacked and Bypassed
    Factory HID Conversion - Flashtech LED Halos
    done's Avatar
    done is online now Hanging out for 8 years
    Old Hickory, TN
    Quote Originally Posted by reSRTrection View Post
    Curious, what is it that a paritcular brand of spark plug does that will destroy a motor? I cannot grasp how that can happen.
    Dec 2009
    Incirlik, Turkey
    i had a 2.4 swapped 1st gen neon with cams and yadda yadda yadda. put BRAND new champion copper plus in it and took it down the road after the swap was done. had 75 miles on it and one of the spark plugs HOLLOWED out. only thing was left was the threads in the head. the porcelain from the plug dropped into the cylinder and took out two valves and the other part of the plug shot up into my hood. i also raced "shifter karts" we had no good iridium NGK left but had an equivalent champion so we put it in. the electrode broke of and got wedged between the piston and one of the intake ports cracking the port and ruining a $300 cylinder. play it safe and run NGK. theres a reason why all the high horse germans run them american car company's are just cheap. i mean look at the lug nuts on our cars aswell..... corrosion under the "cap" on the lug nut and you cant get them off without pounding a socket on it.
    End rant.
