Results 16 to 30 of 31
Like Tree1Likes
Thread: Idle!!!!!!!!
  1. #16
    Largo, FL
    Probably; if you try them post your impressions.
    The reason I don't switch brands is because I know exactly what heat range of NGK plugs came in my car from the factory; 5. Not to mention NGK is one of the best. Point being is that Bosch 5 is not necessarily an NGK 5, for example, and vice versa; different companies can use different heat range scales. Plus by staying with OEM brand you don't need to worry about possible differences in reach or other fitment items. If you do an application check on the website its probably fine.
    An interval really doesn't exist for the PCV valve, just replace it when its bad. If you want an interval... replace every 50,000 miles. And its cheap and easy enough I wouldn't go more than 100,000 miles on one.
  2. #17
    fnkychkn's Avatar
    fnkychkn is offline genuine factory cercumsized sh!tforbrain
    greasy cardboard box
    according to maitenance schedule, PCV valve should be inspected and replaced as necessary every 30,000 miles.
  3. #18
    NYC POPPA is offline LX Padiwan
    Oct 2010
    Queens, NY
    Thanks for all then info guys. I'm just trying to find the right place to buy oem plugs. Also I'm nervous with the one plug that wouldn't come out. The car was cold but I did t wanna crank to hard and snap it in half. Anyway to help get it out ? Also how do you check the PVC Valve to see if it's bad ?
    370 cubic inches of LOVE, HID Headlights and Fog Lights, light window tint, Billy Boat Performance exhaust, Mopar Cai, 180 Jett Thermostat, Razors Edge strut tower brace, Suspension Techniques sway bars, Custom Predator 93 octane CAI Tune, AAC V2 Blue LED scanners in hood scoop and front grill
    NEWSCHOOLMUSCLE.COM
  4. #19
    Sjohalsrt8's Avatar
    Sjohalsrt8 is offline LX Guru
    Sep 2011
    WORLDWIDE
    How often do people change the plug wires on there cars? I'm also having a ruff idle lately on my car, I have a pid selected on my trinity that says misfire counts and that fluctuates alot,one day at a red light it hit 7 times lol.
    Sent from my iPad using Tapatalk
  5. #20
    Largo, FL
    Schedule B. Schedule A is 60k.
    Quote Originally Posted by NYC POPPA View Post
    There's not much that can be said here, put a wrench on it and turn it. If you don't want to turn it yourself have a shop do it and take the responsibility.
    Quote Originally Posted by Sjohalsrt8 View Post
    I don't think people change them that often, if at all. You got me curious about mine now.
  6. #21
    fnkychkn's Avatar
    Quote Originally Posted by srt8-in-largo View Post
    i don't think anyone on this forum drives within the parameters of schedule A.
  7. #22
    Largo, FL
    Thanks, that just confirms that I'm the oddball. :-)
  8. #23
    Sjohalsrt8's Avatar
    Sep 2011
    WORLDWIDE
    So guys I put in the Bosch platinum and they are great!!!!!! My cars idle is very very very smooth now!! I dont have the ruff idle anymore, and the plugs gave me no issues at all!!!!.
    fnkychkn likes this.
  9. #24
    Oct 2010
    Queens, NY
    Which Bosch plugs did you use ? And how and where did you buy them from? lmao i need all this info.... And anyone have a suggestion for a stubborn plug that wont come out ?
  10. #25
    300C-hris's Avatar
    300C-hris is offline LX Guru
    Apr 2008
    Just added a Spartan max cam on my 300C and it idles 720-735 rpm before was around 680-695
    05’ Chrysler 300C Deep Lava Red`
    Inertia Spartan Max Cam, Eagle Heads & Eagle intake w/spacers, SLP under drive pulley, Installed at PLUMFLOORED Creations, Johan Tune, Polished Air Hammer, H&R springs lowered 2.5”, SRT FULL exhaust, DGS ground kit, HIDs 6000K, Tinted LED tails, Catch can, 300SRT wheels, pedderized, 35% tint ALL around, AAC Halos & white LED interior lights, Ported Throttle Body, Custom color matched deep dish grille, R1 Concepts slotted & drilled rotors w/SS lines, 9” monitors in headrest, Plenty More..
  11. #26
    Sjohalsrt8's Avatar
    Sep 2011
    WORLDWIDE
    Hey bro I got them from orileys they are the Bosch 6711 they cost about 3 bucks a plug they worked great!!
  12. #27
    rodneyiii's Avatar
    rodneyiii is offline LX Newbie
    Raleigh NC
    The Bosch 6711 has a different heat range rating than the OEM NGK plugs so you may want to "read" a few of the new plugs after some driving to make sure they have good insulator color (light tan). You don't want them running too hot or too cold.
    2006 Inferno Red SRT8 with groups I, II, Sunroof, K&N drop-in filter, Auto-dim mirror, Jet-180 T-stat, Predator, 300 SRT struts/springs, Chally SRT wheels.
    Born 6-21-06, Home 4-26-10. 1/4 mile - 12.989 @ 108.78 in street trim. Traded in 10-19-2012.
    2006 Inferno Red R/T with R&T Born 8-12-05, Home 8-25-05, Sold 8-9-10.
  13. #28
    Sixpak's Avatar
    Sixpak is offline We all go a little mad sometimes.
    Jan 2009
    Calgary
  14. #29
    Oct 2010
    Queens, NY
    Thanks for all the info guys. Probably just gonna swap my plugs but I'm waiting to find a good price on oem or close to oem plugs. These things are CRaZY exspensive !!!!!!
  15. #30
    rodneyiii's Avatar
    Raleigh NC
    Since we are talking about idle speed - My SRT typically idles at about 700rpm in Drive with a warmed up engine. Sometimes, I'll come to a stoplight and the idle will be at 650rpm instead of the normal 700. If I bump it to Neutral and then back to Drive, the idle will come back up to 700. Does anyone else notice this? It does this with or without the Predator tune installed.
