Page 1 of 3 123 LastLast
Results 1 to 15 of 41
    CVP33's Avatar
    CVP33 is offline Moose & Squirrel did what?
    Feb 2006
    Oak Ridge, NC
    Hotchkis Sway bars and KW V2's
    Finally made the decision on the Eibach vs. Hotchkis sways. I ordered the Hotchkis Sways from AJUSA for $350 delivered. Great price! The KW V2's arrived Thursday from GSM. Super nice and also a great price. Should have these all on by next Friday. Looking forward to a little lower, a little firmer and a lot faster in the twisties. I'll post a full write up once they're on.
    Thanks to Meister and BosChrgrRT for the "preferred" settings.
    QUICKSilver
    2006 300C SRT-8 Option I, II, Kicker, Sunroof, DVD
    Dyno - 625rwhp 558rwtq (9.5psi)
    1/4 Mile 10.956 @ 127.81 mph (10's @ Rockingham damnit!)
    DTP installed ProCharger, HHP/BES forged 6.1, HHP Stage IV cam, AJ tuned, Meister Oil Cooler, Magnaflow mid-pipes, Billy Boat Exhaust, SHR Trans, BB Flexplate, Edge converter, '09 LSD Getrag, Hotchkis Sways, Speedlogix RSTB, BCR coilovers, 3gC Tins, BT everything they make!
    jhs914's Avatar
    jhs914 is offline Aged to Perfection, Old Guys Rule!
    Feb 2005
    Florida
    Quote Originally Posted by CVP33
    Are you selling your SRT8 springs and shocks?
    2005 Cool Vanilla Magnum R/T
    Is life so dear or peace so sweet as to be purchased at the price of chains and slavery? Forbid it, Almighty God! I know not what course others may take, but as for me, give me liberty, or give me death! - Patrick Henry
    When the Government fears the people, there is liberty. When the people fear the Government, there is tyranny. - Thomas Jefferson
    CoolVanilla's Avatar
    CoolVanilla is offline The Dude Abides
    Too funny CVP. I just bought my KW2's from GSM, got my Hotchkis sways from HHP and am having both installed this coming Thurs before the GIFO. Look forward to comparing notes
    boschargerrt's Avatar
    boschargerrt is offline BOSChargerRT
    Feb 2006
    Boston
    you guys are going to love it...just make sure that you decide what height and damper you want for the front and rear...it might be easier to measure from center fender edge to center edge of wheel (rim)....do this before to determine your stock height and how far down you want to go...keep in mind that the front will be lower than the rear when set at the same height....later, jimmy
    Jimmy - BRIGHT SILVER METALLIC SRT8 I,II,III
    2toned Flat Black Vinyl,CarbonbyDesign,Billet Tech Designer,Razor Edge,SpeedLogix,KW v2,Predator 91 tune,22" 3 pc Covet Forged Wheels ,Nitto 420s,BWoody Sway ends,Hotchkis sways,Magnaflow highflow/c-back,DMH electric cutouts,22elite,BND ALL Quantum Blue/ACESIV,Killerglass,GSM intake,Danko v2 spoiler/Chin spoiler,Grip Rockers,Neffywrap
    Meister's Avatar
    Meister is offline 300C pilot
    Arizona
    Remember, also, that your car will settle approx 1/2" front and rear 3 or 4 months post-install. If you're the patient type, do your initial setup approx. 1/2" high and let physics take care of the rest of it. Worst case you'll need a little tweaking at the front end (super easy) and maybe one (only) rear (which are genuine PITAs to adjust height on. Final adjustments at front only will work for most.
    And, remember to set the LF 1/8" higher than the RF to allow for driver's weight to even the front out.
    Finally, setting toe-in at zero is a sweet setting - very quick (responsive), yet stable at speed.
    MattRobertson's Avatar
    Feb 2005
    At the bus stop...
    Quote Originally Posted by Meister
    uhhh. better make that 1/4" for Man Mountain Van Curen.
    CVP33's Avatar
    Feb 2006
    Oak Ridge, NC
    Great advice as usual.
    QUICKSilver
    Quote Originally Posted by MattRobertson
    Eaaaasy there fella. Just cause I outweigh you by like 100lbs...
    So you ARE gonna be there for the install, RIGHT Matt? Someone's gotta pass all this info on to Bob. Yeah, I can do it, but forget it if he asks me any questions.
    Feb 2005
    At the bus stop...
    Quote Originally Posted by CoolVanilla
    Yeah... and are 8 inches taller than me.
    Yeah I'll be there. Provided my engine doesn't explode. Check your email inbox. Looks like I'm for a service call.
    Bob may be building me some new cool stuff; worst case. Who was that guy with the heads? Never mind. More on this as it develops Thursday at SVS.
    CVP33's Avatar
    Feb 2006
    Oak Ridge, NC
    Hotchkis sways arrived today. Drooled all over them just like the KW's. Going to the dealer Monday to get a quote on the install.
    QUICKSilver
    Feb 2006
    Boston
    chris, sweeeet man...i know your itching now...dosn't the setup look so good in the box...call me when you get it done and do you already know the settings yet...later, jimmy
    CVP33's Avatar
    Feb 2006
    Oak Ridge, NC
    Jimmy,
    I'm going to mirror what you and meister posted. I'll use that as a starting point. The rear sways are very heavy, the fronts, not so much. Nice quality all the way 'round though. Always better when you buy the best.
    QUICKSilver
    CVP, I had mine installed yesterday. Here are a couple notes that might be of benefit to you and your installer.
    -The rear end does need to drop in order to install the back sway. Rather than picking off individual pieces, the guys at SVS located the 4 bolts holding the sub frame up and removed them. This had the benefit of dropping the entire rear in one piece and saving a TON of time.
    -The rear sway can be mistakenly installed backward! It goes in fine, bolts up fine looks fine... until you try and roll outta the bay. We made this mistake and messed up a couple of CV boots in the process. The guys at SVS worked like crazy and got the issue resolved in no time, so it wasn't a big deal. But, it otherwise could have been. (PS: The four wheel alignment shop said they'd seen this same mistake many times; its a very easy one to make!)
    -DEFINITELY get the ride height in the rear right the first time. Its a bear to change once the job is done.
    -Enjoy em! They really change the entire feel of the car.
    Ozzie's Avatar
    Ozzie is offline LX Goo'Roo
    SoCal
    This was one of a few tips mentioned in the HOTCHKIS SWAY BAR INSTALLATION INSTRUCTIONS on this thread. Might be worth reading and printing out for whoever is going to install your kit.
    Hotchkis TVS Installation and Evaluation
    CVP33's Avatar
    Feb 2006
    Oak Ridge, NC
    These are going on tomorrow. I'm dropping off my 300 at First TEAM Dodge, same place we had the meet and greet. They're charging me $350 for all four coilovers, the sways and a 4 wheel alignment. That's a little over 4 hours labor at $85 hr. Can't wait!
    QUICKSilver
