Results 1 to 2 of 2
    BMWDON's Avatar
    BMWDON is online now I-495 Hater
    Dec 2004
    Southern MD
    Finally did the trans leak fix...it was getting bad!
    I was trailing funky trans fluid smoke, the leak was just getting worse and worse after hard runs on the road. Bought the part (I don't think they just sell the o-rings anymore, it's now the entire plug with fresh rings on it)...MPSC has them for $6+ or so, I was in a hurry and bought it local for $14.
    Took 1.5 hours to replace that stupid plug under the car lifted probably 10" off the ground, wish I had a lift! And the worst part is working under a hot car and grazing the hot ass cat with the inside part of your forearm right past the wrist....man that f'r is hot! And I changed the oil/filter and washed the k&n filter in the 1.5 hours. So a productive night. Hope I don't see any little (or big for that matter) trans fluid puddles under the car in the morning. But plenty of fluid came douching out of there once you pull that plug, so be sure to use a oil basin to catch it all.
    I've got the new part # at work, I'll post tomorrow morning if you need it or MPSC will give it to you too.
    -Bill
    Challenger Mods: PWR 393, Mean Street heads, Procharger D1 pushing 11+psi, SHR Nag1, DSS 1400 axles and drive shaft, SHR trans but with Paramount Dominator and stage2 valve body to finally be error code/limp mode free. BBS CH-R's and custom splitter with 2011 front spoiler. AAC SMD halos, 3K fog lights, white stripes, cervini wing, hotchkis springs, custom 10" sub w/ kicker amp, sequential tail lights.
    10.89 on Nitto Invo 315/35x20's @18psi in tires. 1.589 60' too! http://www.youtube.com/watch?v=KeXYxSCI_8A
    CVP33's Avatar
    CVP33 is offline Moose & Squirrel did what?
    Feb 2006
    Oak Ridge, NC
    I came back from vacation to find about 3/4's of a quart on the garage floor. Immediately went to the dealer.
    QUICKSilver
    2006 300C SRT-8 Option I, II, Kicker, Sunroof, DVD
    Dyno - 625rwhp 558rwtq (9.5psi)
    1/4 Mile 10.956 @ 127.81 mph (10's @ Rockingham damnit!)
    DTP installed ProCharger, HHP/BES forged 6.1, HHP Stage IV cam, AJ tuned, Meister Oil Cooler, Magnaflow mid-pipes, Billy Boat Exhaust, SHR Trans, BB Flexplate, Edge converter, '09 LSD Getrag, Hotchkis Sways, Speedlogix RSTB, BCR coilovers, 3gC Tins, BT everything they make!
