Page 1 of 3 123 LastLast
Results 1 to 15 of 35
    Burnaby, BC Canada
    Cam install w/ stock heads
    I've only seem to be able to find people that have installed them and done ported heads/intake at the same time. Just wondering if its even worth swapping the stock srt cam out while keeping stock heads/intake.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    What cam?A basic Comp 268 will give you 20hp at the wheels.When you start going bigger head work will compliment the cam you run.
    BFNY PERFORMANCE
    RIP My Friend
    Chrispy is offline LX Padiwan
    Jan 2007
    I asked the same question a week or so ago...You can gain 20-35RWHP at the wheels with a mild cam only swap. (More if you have access to tuning software)
    Thankfully there is no need to pull the heads either, the HEMI's are like the LS1s with lifter retainer clips.
    I am looking at a 216/224 114LSA cam or a 216/230 114LSA cam for my otherwise stock SRT8.
    The new PPP stage two heads look awesome and should give great gains as well.
    2006 300C SRT8
    12.95 @ 106.65mph 1.97 sixty
    Diablo, Magnaflow HF cats
    blk6.1's Avatar
    blk6.1 is offline "Black" The fastest color
    Concord, Ohio
    Quote Originally Posted by Chrispy View Post
    What kind of lift with those duration numbers?
    Jan 2007
    I haven't decided what lobe to use yet but it'll be no more than ~.550 lift. 4 degrees advance as well for both cams.
    Stock manifolds, and magnaflow highflow cats with stock catback.
    Still crunching the numbers but its going to be in that range...
    2006 300C SRT8
    bipto's Avatar
    New Hampshire
    Careful... Because the lifters sit almost horizontal in the block, it is possible to spin the cam to push the lifters back and remove the cam. But the lifter keepers will not prevent the lifters from potentially creeping back and preventing the cam re-install, or worse, falling in to the block.
    The Iron Mistress Galleries
    R.I.P. Dave...
    1FST4DR's Avatar
    1FST4DR is online now I have Gas.. And lots of it ;^P
    Ft Laud.....
    Can you run this cam with stock springs??And if you do,can you change the springs with out removing the heads??
    mexi's Avatar
    mexi is offline thats my sippy cup!
    Feb 2006
    N Misssisspi . Memphis TN
    Quote Originally Posted by 1FAST4DR View Post
    you will be fine...but the 5.7 crowd need 6.1 springs .
    mopar 11
    Corsa Hotchkis ...so far.
    gremlinsteve's Avatar
    gremlinsteve is offline Supporting Vendor
    Apr 2006
    be careful of the lifters. most go qwith heads because they pull them to do the swap. ask me how i know about the lifters falling...
    steve
    gremlinsteve, it does a body good!
    FRANK RACING INC.
    specialized cyl. head development for the 5.7 and 6.1 hemis.
    www.thehemisource.com
    Hemi31's Avatar
    You can run alot of cam on the stock springs.Not sure what the limit is but it's quite a bit.The FRI Hellfire would work very nice with the stock heads and springs.About the same size as the 268 but a bit more computer friendly.
    BFNY PERFORMANCE
    RIP My Friend
    Jan 2007
    You can buy, rent or build a tool to help hold up the lifters. Pen magnets can also work as well. I'll see what I can find on the HEMI platform and post back.
    2006 300C SRT8
    Smoove06CSRT's Avatar
    Smoove06CSRT is offline Kiss my Rims.. They gots BIG lips!
    Nov 2005
    Stock Computer friendly??
    how much would this cam cost.... how much should i expect to pay for install?
    2006 300cSRT8
    Fastest color...... Bright Silver Met.
    "OHH! A Strip Club.....I'll Get my sweat pants on!"
    Hemi31's Avatar
    I ran the 268 on a stock PCm for a few month's.....it took a bit of learning but the PCM finally got it.I believe a Hellfire would run quite well on the stock PCM if it were taught properly.
    As far as install goes it can be anywhere from $400-$1000 depending on the installer.
    BFNY PERFORMANCE
    RIP My Friend
    mjc1241 is offline LX Newbie
    Jun 2006
    I have a PPP Road Warrior cam installed with stock heads, springs, et all. I have not tried to run it with the stock computer as I had a B&G Stage II added at the same time. (Diablo custom tune next) Car runs and idles great and I do not plan on changing the heads any time soon, if at all. The installer said that (as well a noted cam grinder) that our stock heads are great and there is really no need to change them out unless you are going with some SERIOUS mods. The cams that are being cut for these engines are relatively small compared to an LS1/LS2 cam grinds and the two things that hold us back from going more agressive are true tuning and the springs. Not my individual opinion; as I have heard this more times than not. Our heads are more than capable of handling more aggressive cams, thus able to make great power. I will go more aggressive with a custom ground cam through PPP once we get the tuning piece and going with PSI springs.(if I can get them without buying heads) At that point, all I will then add are longtube headers.
    Black 2006 Magnum SRT8
    PPP Road Warrior cam, PPP underdrive pulley, BWoody ported and thermal coated intake, Stock CAI w/Air Hog filter, Jet 180 t-stat, JBA/Borla "hybrid" catback, Kooks LT headers with cats, DC Sports Strut Tower brace, BT Catch can and CMR Tune by Injected Engineering.
    Best ET - 12.541 (Pre TCM)
    Best MPH - 114.50 (Post TCM)
    I HATE COMMERCE!!!!!!
    blk6.1's Avatar
    Concord, Ohio
    Quote Originally Posted by mjc1241 View Post
    Have you run this combo at the track yet? What kind of 1/4 mile ET's are you running?
