Results 1 to 8 of 8
    LawGiver45 is offline SuperBee #328
    Jul 2007
    Paola, KS
    B&G Flash Questions
    I am looking to get a B&G Flash for an 07 Charger SRT-8 and I was wondering why is the Stage II so popular? What are the advantages and disadvantages to going with a Stage III or Stage IV? At my dealer they all cost the same so I just need some opinions on the different stages, I obviously do not want to hurt the engine, but I would like as much power as possible.. -Thanks!
    Super T's Avatar
    Aurora, IL
    Depends on your mods. They're "out-of-the-box" tunes, so a Stage IV probably won't run right at all if you're just mildly modded.
    Jul 2007
    Paola, KS
    What would you recommend for just a CAI and cat-back exhaust?
    hops23's Avatar
    hops23 is offline Motor Fan Club member
    Nov 2005
    Chicago, IL
    Give some of the vendors a call. I got mine from HHP but PPP or Tbyrne can help you with specifics.
    2005 Inferno Magnum R/T AWD traded
    2007 BSM Charger SRT8 traded
    2008 BSM Jeep GCSRT8: Option Group I and II.
    bgchrysler's Avatar
    bgchrysler is offline "DCX" CMR/SCT Tuner
    Mar 2006
    Warren,Michigan
    Lawgiver45, the Stage II calibration will work in almost any application and also will allow you the option to upgrade without sending the pcm back for a reflash. What I would suggest is the Diablo Preditor with the B&G Stage II flash installed as a base file and with the end user timing & fuel adjustments it will have enough adjustment range to run any package from stock to 426 and should get your air/fuel right in the sweet spot for maximum performance.
    bgchrysler's Avatar
    Mar 2006
    Warren,Michigan
    Gentelmen, Also a side note we have all the 08 SRT Stage II flashes done!
    Smoove06CSRT's Avatar
    Smoove06CSRT is offline Kiss my Rims.. They gots BIG lips!
    Nov 2005
    how much would that be above the price of the diablo?
    2006 300cSRT8
    Fastest color...... Bright Silver Met.
    "OHH! A Strip Club.....I'll Get my sweat pants on!"
    DannyC's Avatar
    DannyC is offline Loudest SXT
    Nov 2006
    Lynchburg, VA
    I think the stage III completely disables torque management and make for rough shifts during normal driving. Not sure what the stage IV is.
    For everyday drivers the stage II is the way to go.
