Results 1 to 15 of 27
    bipto's Avatar
    New Hampshire
    300C SRT-8 article - CHECK this out!
    This is great stuff folks... And finally some concrete details / specs on the new 6.1 Hemi... 8)
    http://www.thecarconnection.com/index.asp?article=7410
    E55 KEV's Avatar
    E55 KEV is offline LX Padiwan
    Mar 2004
    Washington D.C.
    Chrysler Boosts 300C SRT-8 To 425 HP
    How much power is too much? If you can't readily come up with an answer, indeed, if you're the type of person who wonders why someone even ask that question in the first place, you're in luck. You'd think Chrysler's 300C would be suited well with its 340-hp, 5.7-liter HEMI - yet there are always those who insist there's room for more. And Chrysler apparently agrees. The carmaker hoped to eke out a modest increase when it decided to bore out the HEMI to 6.1 liters. The results took even the most optimistic powertrain engineers by surprise, confides Dan Knott, director of SRT, the automaker's high-performance operations. How does 425 hp suit you? Read more about the 300C SRT-8 right now:
    Preview: Chrysler 300C SRT-8
    • My Website - www.E55AMG.com
    • 2002 Mercedes-Benz E55 AMG
    • 2005 Dodge Magnum RT Hemi
    • 2005 Chrysler 300C Hemi
    E55 KEV's Avatar
    Mar 2004
    Washington D.C.
    This is a real sleeper however, this will cause a lot of posers and fake SRT-8 modles because all they have to buy is the rims, the front and rear lower bumpers, badges and wholla!
    Unholy is offline LX Padiwan
    Jun 2004
    Riverside, Califorina
    ok... just how much will they give me on trade for my vette?
    Unholy
    [img]ftp://ogg:ogg@64.147.15.11/magnum/notchback.jpg[/img] [img]ftp://ogg:ogg@64.147.15.11/magnum/smallerv.jpg[/img]
    [2005 Magnum RT Notchback] [2002 Corvette Convertible Pewter--For Sale]
    americanbulldog is offline LX Newbie
    May 2004
    Mililani, Hawaii
    I want one! I am holding out for a Charger SRT8 or a 300 C SRT 8. In either case, I want one now!
    2003 Quad Cab Ram Hemi, True Flow intake, Flowmaster cat back, Doug's headers, Hotchkis TVS. 2006 Magnum SRT8, Inferno Red, kicker. True Flow Intake, Corsa exhaust.
    DMAG's Avatar
    Feb 2004
    New Yawk
    Moved to 300C forum.
    Anthony
    liquid's Avatar
    liquid is offline LX Newbie
    Apr 2004
    SE MI
    Jun 2004
    Incase you guys didnt see this....
    Code:
    SPECIFICATIONS
    Dimensions are in inches (millimeters) unless otherwise noted.
    GENERAL INFORMATION
    Body Style Four-door sedan
    Assembly Plant Brampton, Ontario, Canada
    EPA Vehicle Class Large car
    Introduction Date January 2005, MY 2005
    ENGINE: 6.1-LITER, HEMI® V-8
    Availability Std. – 300C SRT-8
    Type and Description 90-degree V-type, liquid-cooled
    Displacement 370 cu. in. (6059 cu. cm)
    Bore x Stroke 4.06 x 3.58 (103.0 x 90.9)
    Valve System Pushrod-operated overhead valves, 16 valves,
    eight conventional hydraulic lifters, all with roller followers
    Fuel Injection Sequential, multi-port, electronic, returnless
    Construction Deep-skirt cast-iron block with cross-bolted main bearing caps,
    aluminum alloy heads with hemispherical combustion chambers
    Compression Ratio 10.3:1
    Power (estimated SAE net) 425 bhp (318 kW) @ 6200 rpm, (69.8 bhp/L)
    Torque (estimated SAE Net) 420 lb.-ft. (310 N•m) @ 4800 rpm
    Max. Engine Speed 6400 rpm (electronically limited)
    Fuel Requirement Premium 91 octane (R+M)/2—recommended,
    Oil Capacity 7 qt. (6.6L)
    Coolant Capacity 14.00 qt. (13.25L)
    Emission Controls Dual close-coupled three-way catalytic converters,
    quad heated oxygen sensors and internal engine features
    Max. Gross Trailer Weight not rated for trailer tow
    EPA Fuel Economy (mpg City/Hwy) 19 hwy/ 14city, 18.4 combined
    TRANSMISSION: W5A580 FIVE-SPEED AUTOMATIC
    Description Adaptive electronic control, Performance tuned AutoStick® driver-interactive
    manual control and electronically modulated torque converter clutch
    Gear Ratios
     1st 3.59
     2nd 2.19
     3rd 1.41
     4th 1.00
     5th 0.83
     Reverse 3.17
    Final Drive Ratio 3.06
    Overall Top Gear 2.54
    ELECTRICAL SYSTEM
    Alternator 160-amp
    Battery H7 Case, 730 CCA, maintenance-free
    DIMENSIONS AND CAPACITIES(a)
    Wheelbase 120.0 (3048)
    Track, Front 63.0 (1600)
    Track, Rear 63.1 (1603)
    Overall Length 196.8 (4999)
    Overall Width 74.1 (1881)
    Overall Height 57.9 (1471)
    Ground Clearance 5.1 (130)
    Frontal Area, sq. ft. (sq. m) 25.8 (2.32)
     Drag Coefficient 0.355
     Curb Weight, lb. (kg)—Est. 4160 (1888)
     Weight Dist., F/R 55/45
     Fuel Tank Capacity, gal. (L) 19 (72)
    (a) All dimensions measured at curb weight with standard tires.
    ACCOMMODATIONS
    Seating Capacity, F/R 2/3
    Front
     Head room 38.7 (983)
     Leg room 41.8 (1061)
     Shoulder room 59.4 (1510)
     Hip room 55.9 (1420)
     Seat travel Driver—10.6 (270), passenger—8.66 (220)
     Recliner angle range, deg. Driver—70, passenger—69
     SAE volume, cu. ft. (cu. m) 55.6 (1.58)
    Rear
     Head room 38.0 (965)
     Leg room 40.2 (1020)
     Knee clearance 4.8 (122)
     Shoulder room 57.7 (1466)
     Hip room 55.9 (1421)
     SAE volume, cu. ft. (cu. m) 51.0 (1.44)
     Total interior volume, cu. ft. (cu. m) 106.6 (3.00)
    SAE Cargo Volume, cu. ft. (cu. m) 15.6 (.442)
    EPA Interior Volume Index, cu. ft. (cu. m) 122.2 (3.46)
    Trunk Liftover Height 30.2 (768)
    BODY
    Layout Longitudinal front engine, rear-wheel drive
    Construction Steel unibody
    SUSPENSION
    * Performance tuned front & rear suspension
    Front Independent SLA with high upper “A” arm, lateral and diagonal lower links
    with dual ball joint front knuckle, coil spring over gas-charged
    shock absorbers and revised stabilizer bar lower “A” arm
    Rear Five-link independent with coil springs, gas-charged shock absorbers
    and isolated suspension cradle. Revised rear stabilizer bar
    STEERING
    Type Rack and pinion with hydraulic power assist
    Overall Ratio 16.1:1
    Turning Diameter (curb-to-curb) 38.9 ft. (11.9 m)
    Steering Turns (lock-to-lock) 2.75
    TIRES
    Standard – 300C SRT-8
     Size and type P245/45R20 - Front
     P255/45R20 - Rear
     Mfr. and model 3 Season Goodyear F1 Supercar
     Revs per mile (km) 729 (452) Front , 720 (447) Rear
    Optional – 300C SRT-8
     Size and type 245/45R20 - Front
     245/45R20 - Rear
     Mfr. and model 4 Season Goodyear RS-A
     Revs per mile (km) 729 (452) Front , 729 (452) Rear
    WHEELS
     Type and material Forged Polished Aluminum
     Size 20 x 9 in.
    BRAKES
    Front
     Rotor size and type 14.2 x 1.26 ( 360 x 32.0 ) vented
     Caliper size and type 1.73 (44) Brembo 4-piston fixed with aluminum housing
     Swept area 351 sq. in. (2261 sq. cm)
    Rear
     Rotor size and type 13.8 x 1.10 (350 x 28) vented
     Caliper size and type 1.26 (32) Brembo 4-piston fixed with aluminum housing
     Swept area 316 sq. in. (2036 sq. cm)
    Four-wheel anti-lock and traction control Std
    Electronic stability control and brake assist Std
    Power assist type
    Std. on 300C SRT-8 8x9 (203 x 229) active tandem-diaphragm vacuum booster
    Unholy
    AlbertFattal is offline LX Newbie
    Apr 2004
    POWERTRAIN:
    6.1L HEMI
    85 more HP
    425 HP
    420 Lb.-Ft. Torque
    Bored out 3.5mm per cylinder
    Compression ratio was increased to 10.3:1
    Specially designed intake maniford
    New individual heads made of a stainless steel shell
    Larger Valves
    2.75" exhaust system with 3.5" chrome tips
    Performance camshafts
    Reinfoced engine block
    Forged steel crankshaft
    Upgraded Differental and axles
    Lowered suspension
    20" forged aluminum wheels
    Specially designed Brembo brakes
    0-60: "low 5's"
    1/4: "high 13's"
    PHOTO OF PROTOTYPE ENGINE:
    PHOTO OF PRODUCTION ENGIE:
    scooter is offline LX Newbie
    Tampa, Florida
    All this FROM Chrysler! Now, I really can't wait for the Charger! Make mine Red with a 6-Speed and a 6.1L Hemi with 425hp :D My friend with his 2004 GTO has some competition coming 8)
    BrilliantBlackHemi's Avatar
    Feb 2004
    Been here 7 years!
    Interesting there is a Mobil 1 filled oil fill cap on that production engine and not on the 5.7L Hemi.
    R.I.P. Dad aka DynoBob
    E8502's Avatar
    E8502 is offline The Swiss Cheese
    Feb 2004
    Massachusetts
    Quote Originally Posted by scooter
    Same here... AWD is still on the way... The Charger... :lol:
    Chris ~
    '01 LHS • '01 Dakota Sport • '04 Sebring Convertible • '05 Grand Caravan
    mexSSican is offline LX Newbie
    Anyone know if theres any plans of a AWD 300C SRT-8?
    E55 KEV's Avatar
    Mar 2004
    Washington D.C.
    I seriously doubt it. There are no longer any AWD AMG cars and I doubt that the Mercedes 4-Matic system can handle the power and torque.
    E8502's Avatar
    Feb 2004
    Massachusetts
    Quote Originally Posted by mexSSican
    I was told no by a source in Aurburn Hill. :?
    Chris ~
