220/220 Inertia Cam
A Forum member is selling this, and i am very interested in purchasing it
i havea 06 Charger SRT8 with a MOPAR CAI and Predator Tune, will it be safe to direct drop in this cam with stock internals? because i know the Spartan cam which is one of inertias only cam thats a direct drop in is only a 214/218 Duration Camshaft, so i wanted to make sure i talked to some of the gurus on here before i went ahead and made any decisions.
i dont wanna make the purchase till i know i can do a direct drop in, thanks guy!!
It's more about the lift than the duration when talking about keeping the stock springs or upgrading to aftermarket springs. But to answer the question yes the OEM 6.1 springs will be fine with that cam. Your car being an 06 I would freshen them up (replace) with a new set.
- You may not post replies
- You may not edit your posts
Forum Rules
