Its a Canned tune, very basic adjustments to fuel/Spark and should make some shift feel adjustments if you select those QA paramerters.
And you can modify any of the tunes on there. Be it the 93 CAI or 91 Performace Tunes. You dont have to be just modifying the stock tune you can modify the can tunes as well.
Also not holding and turning off the esp will effect your numbers. Thats why you see that wave in your lines.
Here is an example of an SRT on the dyno with ESP off.
Thats smothing 5 if I am reading it right.
And like I said, you got ripped, that 3rd pull is a throw away unless they did another and it did the exact same thing.
I would thing the only read to see that kind of dip would be some knock going on and the computer pulled timing. Did you data log ?
-R
