Page 1 of 4 123 ... LastLast
Results 1 to 15 of 48
    IGOTTASRT8 is offline LX Newbie
    Oct 2005
    Los Angeles
    125 shot of N20?
    Just wondering if anybody has tried jetting for 125 or 150 shot of nitrous. How did it work out?
    I'm currently jetted for 100hp and it seems fine.
    GSM Track Mod
    Mopar CAI
    Stant 170 Thermostat
    12.2 @ 116 Famoso Dragstrip
    MomsR/T's Avatar
    MomsR/T is offline Builders of the 500rwhp 426's
    Houston
    bad idea w/ stock cam........if you had more overlap it might be okay................but then you'd need a B&G to handle it.
    A 100 shot can get you about a 11.7 - 11.9 @ 120 - 117 mph...........
    Oct 2005
    Los Angeles
    Quote Originally Posted by MomsR/T View Post
    Thanks for the info.
    BTW- My 100 shot has taken me a quickest of 12.4, that's after 60+ passes on the bottle. I don't think I've ever seen more than 114 mph.
    But, my car is filled with stereo stuff and I can't so that may have something to do with it. Oh, I too much and weigh 270.
    GSM Track Mod
    Mopar CAI
    MomsR/T's Avatar
    Houston
    try some hi-flo cats to really help your combo out...........
    When you compress that much air it needs some place to go right?
    N2O is 33% pure oxygen.................couple that with the idea it is -30* F and makes the hot combustion chamber expand..........
    All that pressure needs to flow out..............
    Your stock headers work well...............the cats will really shine on the N2O setup.
    Add a B&G and a cam and wha-la............
    bklynmag is offline Maggie under construction
    Brooklyn, N.Y.
    60+ Passes? . . . .Nice
    1FST4DR's Avatar
    1FST4DR is online now I have Gas.. And lots of it ;^P
    Ft Laud.....
    You may want to explain this to NEED4speed06.Hes been running 150 shot for quite a while now..Didnt have any problems until he started with a set of street radials and broke 2 half-shafts..Stock cam and all...No problems motor wise
    Super T's Avatar
    Aurora, IL
    Quote Originally Posted by 1Quickchick View Post
    Just cuz' he's going fast doesn't mean he couldn't be going faster
    Those half shafts have to get some help though. 150 is way more than I'd consider running. The juice really is just like crack for your engine. I don't care what anybody says, running a large charge WILL reduce the lifespan of your internals. Best to build 'er up and use the bottle as the icing on the cake for the last 75-100 worth.
    1FST4DR's Avatar
    Ft Laud.....
    I agree about the half shafts..I also agree that 150shot is pushing the limits..But Scott"NEED" drives his car dailey and has no issues..Except at the track with the half shafts..As far as life span on an engine??I think all power adders do that to one degree or another,
    MomsR/T's Avatar
    Houston
    I felt the question was asked and I answered with my professional oppinion.............
    Some guys ride motorcyles without helmets............I do not advise that.
    One of "our" cars runs a 100 shot and runs high 11's...........I feel I know what it takes to do it safely.............NEED going faster?
    We haven't been breaking axles............
    We haven't been blowing motors.............
    Fogging infront of the throttle CAN lead to issues once you up the dope..........direct port is a WHOLE other consideration.
    Another issue is the tollerances of the top ring on the pistons..........if NEED is loose but within spec, he got lucky.............then you tell this guy its "safe" and he tries and blows it all to hell.
    Nah...............my opp. is that he puts on the cats, B&G, and cam and runs high 11's and run the car over a longer period of time. If he then REALLY wants to go faster, then we'd recommend he runs a direct port so you can distribute fuel properly.
    chiromikey is offline LX Newbie
    i'm glad you're now on board with the mph it takes to run 11's but there's no way a 100 shot (by itself) will yield 11's for the average srt8 running somewhere other than atco, mir, or one of the few other record setting tracks.
    mid 12's is more like it.
    MomsR/T's Avatar
    Houston
    Quote Originally Posted by chiromikey View Post
    dude.......go away.
    You add nothing to a conversation and I'm not going to discuss anything with you because you're a troll.
    I never said N2O ONLY will do anything.............I mentioned what need to be addressed...........and what needs to be addressed isn't more nitrous sprayed in front of the TB.
    As for MPH vs Times......................our converters are here, the arguement is now over.
    wow, I had no idea you were still upset about that. get over it, we're all wrong sometimes and I hope to see you finally prove me wrong with your new converter. please post some timeslips when you get a chance.
    however, you did make a blanket statement by saying a 100 shot would net 11's which we know alone it won't.
    btw, how's that suspension coming?
    MomsR/T's Avatar
    Houston
    fishing again eh?
    Go look at what I said.............the last sentence of that post explains what is needed by this individual. (and yes, our guy only used a 100 shot)
    If you want time slips and to understand what these converters are doing read the FORUM and become and asset to the community.
    Feel free not to hijack this person's thread; I have no illusion of thinking anyone misunderstood my point and know you didn't either.
    ASU_Magnum's Avatar
    ASU_Magnum is offline I'll be back...someday
    Nov 2005
    Phoenix
    chants: MOMSR/T, MOMSR/T, MOMSR/T
    lol
    anyways, lee knows his sh*t. i'd take his advice.
    2005 Magnum SXT Bright Silver - SOLD
    2006 Yamaha R6 Raven -STOLEN
    Quote Originally Posted by Zmagnum
    You are famous. You have the fat woman sittin' crack findin' Magnum
    fishing??? get over it, I WAS ASKING SINCERELY. if you really want another verbal smackdown keep it up (but please do it via pm's so the board doesn't have to suffer).
