Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Jweezy's Avatar
    Jweezy is offline J to da Weezy..Baby!!
    May 2006
    Virginia
    So butt load of oil leaked out of my car Friday
    The same day I resolve my problem with my overheating and Heating system - (resolved - Low on coolent.)
    I drive home and everything is perfectly fine until something very weird happens.
    I hear very a loud noise coming from my engine bay as soon as I am about to back-in to my driveway, I find oil on the street and on my driveway trailing my car...thats weird.
    I see a little puff of smoke come from my engine, as if something dripped onto my exhaust or a very hot section of my engine.
    The engine noise becomes very aggressive, when I turn the wheel either way, I put the car on the street in front of my house because I didnt want the oil in my driveway and garage
    It continued to slowly spill, however it was too cold for me to work on it, plus its on the side street.
    I want to put it in my garage to work on it, I just dont know if I should move it if it is the power steering fluid (which I think it is)
    The coolent is still there and I am not getting any engine errors in my dash either.
    I havent been able to get under my car yet to actually see where its coming from, for the fact its in front of my house on the street that has cars past about about 25 - 35 mph, also the the street has a slight slope.
    Any ideas?
    Cam's Avatar
    Cam
    Cam is offline effectiveness is not always pretty
    Oct 2005
    Riverside, Ca
    What you do you mean you took care of the coolant issue, whatta ya do.
    Also what color is the fluid?.
    DreamWeaver's Avatar
    DreamWeaver is offline 05 300c 5.7
    May 2010
    Providence, Rhode Island
    First check your oil levels and verify what it is.you probably blew a pwr steering hose
    Edit. I say pwr steering cuz the noise u mentioned when turning the wheel. But don't drive it until u know what it is your leaking
    compcam 268 / beehive valve springs / titanium retainers/ chromoloy push rods / slp underdrive / k&n intake / diablosport /
    20" staggered vipers / nitto nt420 / bbk ceramic shorties / jba catback / 35% tint / 6k tops 3k 55w fogs / e%g classics grille /
    tein 2" drop springs / all led interior / ipac ipod / ebc slotted and drilled rotors/ ebc redstuff pads / russell ss lines / motul dot 5.1 fluid / Johan tune / SRT front bumper
    Jweezy's Avatar
    May 2006
    Virginia
    Quote Originally Posted by Cam View Post
    Thanks for the reply.
    I was low on coolent, that day my heat was not working unless I had my foot on the gas. I posted on the forum, and it was low, so I put in some 50/50 easy fix.
    I will be leaving work early to really get to the nitty gritty. I just need to know what I should be prepared for, or if I should pick up anything on my way home to help me troubleshoot.
    Jweezy's Avatar
    May 2006
    Virginia
    Quote Originally Posted by DreamWeaver View Post
    Will do, I know that should have been one of the areas I checked, I was just so mad it happened, because it seems like its always something now...
    I will be leaving work around 1pm eastern time to see what is going on for real.
    FleshWound's Avatar
    FleshWound is offline Putting on the Foil
    Jan 2007
    Isle of Lucy
    check the engine oil first
    check the power steering reservoir, add if needed, fill to desired level and get her to your garage to source the problem. I'm guessing the noise you heard was from the PS pump whining due to low fluid
    Jweezy's Avatar
    May 2006
    Virginia
    Quote Originally Posted by FleshWound View Post
    I attempted to power wash the fluid off my driveway and part of the street. didnt do much.
    However, when it happened and I parked my car, I tested it with my finger, and it doesnt seem like it is thick enough to be oil
    I will check it when I get home also.
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    I seem to remember when my car was fairly new, 50,000 miles or so, the dealer had it on a lift for oil change and found a chafe on one of the power steering hoses. It was starting to leak. Dealer replaced the hose, no charge and put some chafing protection where it had chaffed. So far it's never bothered. I know a few guys have had leaks at the rack, as well. Get some Dawn dish washing liquid in some hot water and a broom for the driveway, then hose it off. Good luck, hope it's minor.
    Jweezy's Avatar
    May 2006
    Virginia
    The sound increases when as I press on the gas. I took of the bottom cover and I see the fluid on some of the hoses and also on the front frame, and engine components. I checked the steering fluid and it is very low, I know if I put some in it will leak again if it is the hose like formierce said. so now I have questions
    What kind of fluid do I use for steering fluid.
    Best way to troubleshooting this issue?
    If hose is leaking how do I seal it?
    thanks everyone, I am on the site using cell, sorry for format
    MatcoDave's Avatar
    MatcoDave is offline LX Padiwan
    Jul 2009
    Dallas, Tx
    Quote Originally Posted by Jweezy View Post
    If the hose is leaking, replace it.
    Attitude Reflects Leadership!
    PaCharger's Avatar
    Oct 2005
    Supercharged 2012 Audi A6
    yeah, it's a high pressure hose...no fixing or bandaid..it's a quick easy replace.
    I'd look for a leak on the pump fitting, or a small cut from bumping a pulley - it happened to me at 120 mph on the NJMP track day...
    it could have been hit to by road debris if you don't have belly pans on as well.
    Jweezy's Avatar
    May 2006
    Virginia
    Def power steering. Poured some ps fluid in and noise went away. As soon as I 5urn steering wheel it spits out, byt i don't another person right now to help, can't be 2 places at once. My girl is at school and its dark and in the 20s. will continue tomorrow.
    sent from my Evo phone
    Jweezy's Avatar
    May 2006
    Virginia
    Pa I took some pics for you
    elarm1's Avatar
    elarm1 is offline LX Padiwan
    Aug 2010
    N. VA
    gimme a call pm'd
    05 Mag r/t
    Mopar hitch and ball, bbdb7, K/N intake, 91octcai tune w/predator, 6.1 mm's, MSRT Wheels, 5k Low 3k fog HID's, STANG and TRASH HAULER!!!
    07 Camry SE V6
    15% tint, 20's, HID's, Wife's Ride
    91 Stang LX
    Motor Rebuild Done! 12 Sec street tire MOPAR CHEVY KILLER! 306, AFR's, Trick Flow Intake, T5Z, 373's, 5 lug conversion w/03 Cobra wheels, MM suspension goodies, Shaved weight
    2009 ZX10R
    Get out of Jail Free Machine!
    2009 ZX6R
    Track bike
    May 2010
    Well when you have someone to give you a hand. Put fluid in it. Start the car and then have the person turn the wheel clock to clock. All the way left and hold then all the way right and hold. When you hold the wheel all the way in one direction or the other the system is put under a load, under this added load you should be able to easily see where it leaking from. Use dot3 power steering fluid.
