    craiglf is offline LX Newbie
    Powertrain Vibration
    I have a Charger with 6000 miles on it. About 200 miles ago I noticed a vibration in the seats, floorboards, and steering wheel. It is not a shaking, feels like the powertrain such as the driveshaft. Anyone else have something similiar? Thanks
    wheelife's Avatar
    wheelife is offline Making fast go faster.........
    Oct 2005
    Fredericton New Brunswick
    Welcome to LXfrorums.. craiglf, just a wild guess, sounds like a problem I have had with other euro cars.. My guess would be the guibo joint is failing.
    fnkychkn's Avatar
    fnkychkn is online now genuine factory cercumsized sh!tforbrain
    greasy cardboard box
    possible transmission/torque converter shudder.
    TSB 21-003-06
    SUBJECT:
    Dipstick Tube Seal May Leak Causing ATF Contamination Or Transmission Shudder/Buzz
    OVERVIEW:
    This bulletin involves tests to be performed on the transmission to determine the integrity
    of the transmission oil fill tube seal. Dependent upon test results: the oil tube seal will
    require replacement, the transmission may require a flush procedure, and/or the
    transmission torque converter may require replacement.
    MODELS:
    2005 - 2006 (LX/LE) 300/Magnum/Charger
    NOTE: This bulletin applies to LX/LE vehicles equipped with a NAG1 transmission
    (sales code DGJ) that were built prior to December 2005 with a
    TRANSMISSION build date of July 08, 2005.
    SYMPTOM/CONDITION:
    Water may leak past the transmission oil fill tube (dipstick tube) seal. Dependent upon the
    amount of water accumulation in the transmission oil, the customer may experience a
    transmission shudder vibration and/or an audible high frequency buzz-like sound. The
    shudder vibration or buzz-like sound may be most noticeable during light acceleration
    where partial application of the torque converter clutch (TCC) in 3rd, 4th, or 5th gear
    occurs.
    The shudder/buzz condition may be due to the torque converter clutch and a “stick-slip”
    condition caused by contaminated transmission oil/fluid. The transmission fluid
    contamination may be caused by water intrusion past the transmission fill tube seal.
