Just wondering what all is in the police package on the charger, and what the difference is between it and the regular package that is found on the SXT?
Thanks guys in advance.
"With Great Power Comes Great Responsibility!"
Slightly higher top end speed
Additional wiring harnesses for police lightling packages
Additional fuse block and wiring on the passanger side under the dash
Shifter re-located on the dash instead of the centre console (only has PRND)
center console removed and replaced by anodized aluminum plate for mounting police radio equipment etc.
Steel rims to meet the police requirements
Upgraded rotors and calipers
Slightly more powerful alternator and battery combo
Option for 'A' pillar directable flood lamps
I think thats most of it..... I dont have the Upfitter guide in-front of me.. but if I remember ... thats most of the upgrades thought e book doesnt mention most of that as its meant for the after-market installers to locate tie-in points etc.
Russ
- Falken 20" Explict Black rim,Falken 255 45 20 tires,8"LCD monitor headrests,12" LCD monitor in custom tri fold in back,custom made CIA,Infinity engine cover w/custom paint,custom painted centre bezel & console,custom lit cup holders, LED interior lighting & grill lites,HID's,300w sub amp w/custom enclosures,custom hand-made mesh grill
Is there somewhere online I can see a list of the options?
I am just wondering what all the differences were. My uncle was looking at one but didn't know what all was the difference
To quote the spec sheet.
"Standard on all Dodge Charger Police Models:
~ Air bags* - Advanced multistage driver an front passenger air bags
~ Air Conditioning - Manual
~ Brake/Park Interlock - Driver must apply brake before shifting from Park
~ Defroster - Electric, rear window
~ Guages - 260 km/h (160 mph) speedometer, tachometer, odometer, trip odometer, fuel level and coolant tempurature, low fuel and low washer fluid seat belt reminder, door/trunk ajar, cruise, brake system, headlight high beam, turn signals, engine and air bag
~ Instrument cluster - Electroluminescent display
~ Keyless entry/illuminated entry
~ Lighting, Exterior - Quad halogen headlights with automatic off feature, tail lamps and centre high mounted stop lamp
Interior - Dual front map lamps, trunk lamp
~ Mirrors, Exterior - Dual power
Interior - Day/night centre rear-view
~ Seat Belts, Front - Height-adjustable, outboard shoulder belts, three point
Rear - non adjustable shoulder belts, three point
~ Speed Control - Electronic with steering column mounted controls
~ Steering Column - Tilt
~ Windows - Power with drivers one touch down feature
~ Wiper SYstem - Windshield, two speed with variable intermittent modes
Standard Police Equipment
~ 3.5 - litre V6 engine with 186 kW (250hp)@ 6400 rpm and 339 N.m (250 lb-ft) of torque @ 3800 rpm (certified on mid-grade unleaded fuel)
160- amp high output alternator
~ 260-km/h (160-mph)(certified) calibrated speedometer
~ 18X7.5-inch steel wheels
~ 800 CCA battery
~ am/fm stereo radio with cd player, changer controls, four speakers, and clock with auxiliary audio input jack
~ Mini floor console
~ Easy path wiring grommet between under hood and passenger compartments
~ External Oil Coolers: Engine Oil, Transmission fluid, power steering fluid
~ Engine block heater
~ Five-speed automatic transmission with overdrive and Auto/stick
~ Four wheel heavy-duty anti-lock brakes
~ Four-wheel independant performance suspension
~ Heavy duty cloth front bucket seats with manual lumbar and rear fixed cloth bench seat
~ Column shifter with Auto/stick
~ Load leveling, height control shock absorbers
~ P225/60R18 BSW V-rated performance tires
~ Police equipment mounting bracket
~ Police performance Electronic Stability Program (ESP) with Brake Assist and all speed traction control
~ Police performance tuned steering
~ Trunklid key lock cylinder
~ Security Alarm
~ Separate key and key fob
~ Severe duty cooling system
Standard Police Electrical Equipment
~ Centre instrument panel stack power connection with three 20 amp fused battery feeds and three 20 amp fused ignition feeds
~ Dome lamp switch deactivated
~ Dual spot lamp prep package
~ Integrated engine hour meter
~ Police equipment interface module
~ Separate fuses for left and right battery fed spot lamps
~ Software controlled alternating head and tail lamps (wigwag)
~ Stealth mode switch (turns off instrument cluster and radio indicators: PRNDL dims to lowest legal limit)
~ Three pairs of 18 gauge wiring for siren, speakers, or controls provided from interior to front bumper
~ Under hood lamp"
I didnt include the Optional Police Equipment
i'm HOPING that optional equipment includes a HEMI?
Click here to Join the Great LX Weight-Off!
Click here to Track the Progress!
The leading authority on Anti-MTV ConsumerBotism.
I'm a real estate agent let me know if i can help you!
the police chargers and Magnums here in Reno, NV have a 4.0L jeep engine in them I think. the guy driving it that I talked to told me but I forgot. I believe it was a V8 around 4.0L
Thanks Cdn_Magnum.. I am going to pass this info on to my Uncle
Exactly. They come as listed. No other 'factory' engine options available, so buddy was yanking your chain or hasnt a clue what they have under the hood. Been to the plant for a tour for police purchacing, so I can tell you there is no other engine combinations.
There are very few 'additions' to the police package over the standard package. Most of it is wiring and some tweaking to the engine module. You have to remember also that these things typically go to auction after their life as a police cruiser, so theres not going to be anything major done to them at the factory level. Even the CV Police Intercepter is nothing special... infact the V6 Dodge is ONLY 1 second slower from 0 to 60 mph and the V6 Dodge will out brake the CV![]()
Not sure if this was mentioned, but the Police packages are also able to Totally disable ESP. By holding down the ESP button. It also displays in the EVIC, "ESP Disabled".
