Results 1 to 9 of 9
    MeSteve's Avatar
    MeSteve is offline Sublime # 107
    Jan 2007
    Crestview, FL
    New Headlight bulbs
    Has anyone been able to get the right angle 2006 bulbs into our housings?
    I want to try some 80w bulbs, but they apparently only come in the 90 degree plug angle.
    2007 Charger, Sublime Green # 0107 (US)
    Fogs enabled w/ High beams, Underhood Light, Cabin air Filter, Hood Struts, Glovebox Light, uConnect mirror (w/o telematics at this point)
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    80W, yikes that's a lot of current! Might want to check to see if they will even work on our cars first, the computer sensed those voltages and regulates the headlights with those inputs.
    ohiocharger's Avatar
    ohiocharger is offline LX Newbie
    Jun 2006
    Cincinnati,OH
    Don't do it!!! I used 85w bulbs and burned out the factory connector... Plus the 90 degree bulb will not work. Get the 9006xs bulb.
    HOT ROD MAGNUM's Avatar
    HOT ROD MAGNUM is offline LOOKIN TO LEARN
    B.C. canada
    I burned mine up with 80's aswell. i tried 100's too. Hid was the only way to go for me.
    MeSteve's Avatar
    Jan 2007
    Crestview, FL
    PaulFix's Avatar
    PaulFix is offline Mr. White Chocolate P. Rock
    May 2005
    BC, Canada
    You might consider HIR bulbs also, IMO they are twice as bright and use the same amount of power and cost a lot less than HID
    Dodge Magnum RT AWD MDH=Jan 19th 2005 7-8pm
    Tow package, Midnight Blue, Painted spoiler body colour, Auto headlights, HID lows, Fogs on with Hi beams, SC flash with custom tranny and 91 tune, RER MyGig installed, Tranzformer, Resonators deleted, Custom Stainless intake.
    160,000km driven very hard, repairs include replaced front brake rotors and pads $200, rear pads$, ebrake shoes, all 4 tie rod ends $50ea (only 1 was loose), front sway bar rubber bushings $25(first thing to check if front is clunky); 3m refinished headlights WOW $30, 4 sets of tires, 2 tranny filter and flushes,
    MattRobertson's Avatar
    MattRobertson is offline A Wealth of Useless Information
    Feb 2005
    Near salt water
    Another vote for HIR's. Unfortunately I do not know of a source that works on the Charger, which has those stupid 90-degree bulbs that neither the C or the Magnum have.
    PaulFix's Avatar
    May 2005
    BC, Canada
    Ahh,I did not look at hs sig to see he has a Charger
    joseph's Avatar
    joseph is offline Banned
    Oct 2004
    Las Vegas, NV
    I had Sylvania ST's, were ok, then I had HIR's, brighter, but not by much and too yellow for my taste, not worth it, now I have HID's, I'm never going back, from now on every car I and my wife own will have HID retrofit, there is no comparison, HID is just so damn better, and for less than $200, it's worth every penny and some.
    HID flickering fix.
