Results 1 to 7 of 7
Thread: Need some help
    Skreechy's Avatar
    Skreechy is offline LX Padiwan
    Need some help
    I was trying to install some light's in my trunk and I tried to hook them up to the trunk light and I think I messed something up.I might have blown a fuse but I don't know what fuse it is.My trunk light and my compass doesn't work now any one know what fuse I need to check??
    Mods Dub CAI Billet oil raid and washer cap SRT underhood letters SRT valuve stem caps 15% tint Flowmaster series 40 no ressornators Diablo Predator Detroit Redwings painted fuse box cover and strut covers
    jarpod's Avatar
    jarpod is offline LX Newbie
    you could check on your owners manual which fuse powers the trunk light....
    Mighty Noid's Avatar
    Mighty Noid is online now time to paint the car soon!!!
    Aug 2005
    SoCal
    '06 charger trunk light fuse is #38 in rear PDC
    Thank you Bigal470
    BUTWEET's Avatar
    BUTWEET is offline GOOD MEAT TAKES A LONG TIME!
    Bothell, WA
    Here's a list of fuse numbers and locations, per the chicken.
    these are for '06 magnum but should be the same for all LXs.
    Power Distribution Centers
    Front Power Distribution Center Fuses
    A power distribution center is located in the engine compartment. This center contains fuses and relays.
    CAUTION:
    • When installing the Power Distribution Center cover, it is important to ensure the cover is properly positioned and fully latched. Failure to do so may allow water to get into the Power Distribution Center, and possibly result in a electrical system failure.
    • When replacing a blown fuse, it is important to use only a fuse having the correct amperage rating. The use of a fuse with a rating other than indicated may result in a dangerous electrical system overload. If a properly rated fuse continues to blow, it indicates a problem in the circuit that must be corrected.
    Cavity/ Fuse /Circuits
    1/ 20 Amp Yellow/ Left High Beam Headlight
    2/ 20 Amp Yellow/ Right High Beam Headlight
    3/ 15 Amp Dk. Blue/ Adjustable Pedal
    4/ 20 Amp Yellow/ Horn
    5/ 25 Amp Clear/ Headlamp Washer — If Equipped
    6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
    7/ 20 Amp Yellow/ Fog Lamp
    8/ 15 Amp Dk. Blue/ Park Lamp
    9/ 15 Amp Dk. Blue/ Non ABS Brakes
    10/ 5 Amp Orange/ Starter
    11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
    12/ — —
    13/ — —
    14/ 25 Amp Clear/ Powertrain Control Module
    15/ 20 Amp Yellow/ Injectors, Ignition Coils
    16/ 15 Amp Dk. Blue/ Powertrain Control Module
    17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
    18/ 30 Amp Pink/ Windshield Wiper/Washer
    19/ 50 Amp Red/ Radiator Fan
    20/ 20 Amp Lt. Blue/ Starter
    21/ 50 Amp Red/ ABS Pump Motor
    22/ 40 Amp Green/ Radiator Fan High/Low
    23/ 50 Amp Red/ High Intensity Lighting
    24/ — —
    25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
    26/ 20 Amp Lt. Blue/ Transmission
    27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
    Rear Power Distribution Center Fuses
    There is also a power distribution center located in the trunk under the spare tire access panel. This center contains fuses and relays.
    CAUTION:
    1/ 60 Amp Clear/ Ignition Off Draw
    2/ 40 Amp Green/ Battery
    3/ — —
    4/ 40 Amp Green/ Battery
    5/ 30 Amp Pink/ Heated Seat/Steering Column
    6/ 20 Amp Yellow/ Fuel Pump
    7/ — —
    8/ 15 Amp/ Dk. Blue Ignition Start/Run - Start
    9/ 20 Amp Yellow/ Console Power Outlet
    10/ 10 Amp Red/ Rear Fog Lamp — If Equipped
    11/ 25 Amp C/BRKR/ Memory Module/Door Locks
    12/ 25 Amp C/BRKR/ Passenger Power Seat
    13/ 30 Amp C/BRKR/ Door Module Run/Acc/Delay
    14/ 10 Amp Red/ Sentry Key/Remote Keyless Entry/Cluster
    15/ 20 Amp Yellow/ Brake Light (5.7L)
    16/ 20 Amp/ Yellow/ Power Outlet Trunk - if equipped
    17/ — —
    18/ 20 Amp/ Yellow Selectable Power Outlet
    19/ 10 Amp/ Red Stop Lamp
    20/ 20 Amp Yellow Rear Wiper — If Equipped
    21/ — —
    22/ — —
    23/ — —
    24/ — —
    25/ — —
    26/ — —
    27/ 10 Amp Red/ Airbag/Occupant Classification Module
    28/ 10 Amp Red/ Curtain Airbag - if equipped
    29/ 5 Amp Orange/ Sentry Key/Remote Keyless Entry/Powertrain Control Module Ignition Feed
    30/ 10 Amp Red/ Steering Column Module/Power Mirrors - if equipped
    31/ — —
    32/ — —
    33/ — —
    34/ — —
    35/ 5 Amp Orange/ Power Antenna/Garage Door Opener/Ignition Delay
    36/ 20 Amp Yellow/ Radio/Navigation
    37/ 15 Amp Dk. Blue/ Transmission
    38/ 5 Amp Orange/ Analog Clock/Garage Door Opener
    39/ 10 Amp Red/ Heated Mirror
    40/ 5 Amp Orange/ Power Mirror
    41/ 10 Amp Red/ Climate Control Module/Headlamp Leveling — if equipped/Rear Park Assist — if equipped/Tire Pressure Monitoring — if equipped
    42/ 30 Amp Pink/ Automatic Temperature Control (ATC) Blower Motor
    43/ 30 Amp Pink/ Rear Defroster
    44/ 20 Amp Lt. Blue/ Audio Amplifier
    MY MEAT WILL MELT IN YOUR MOUTH....NOT IN YOUR HANDS! ENJOY THE Q.
    Aug 2005
    SoCal
    Weet...
    I think that you forgot to copy that entire list because there was an edit on the bottom of the page... that is where I got that info because I blew that fuse last year...
    I tired to copy and paste that same thing and it wouldn't let me.
    Thank you Bigal470
    BUTWEET's Avatar
    Bothell, WA
    Quote Originally Posted by Mighty Noid View Post
    Weet...
    You mean this edit that you've already posted?
    EDIT: '06 charger trunk light fuse is #38 in rear PDC
    Aug 2005
    SoCal
    that's the one....
    Thank you Bigal470
