Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    Talking My assessment of FlashPaq in a Charger R/T
    Brothers and Sisters and other members of the Grand Congregation of the Temple of Our Holy Lady of Massive Horizontal Acceleration and The Holy Order of Speed, Style and Plain Ol’ WhoopAss, The time has come for me to give testament to the Sacrament of power offered to us as:
    FlashPaq!
    Now Laypeople, Preists, Inquisitors, and Newcomers I shall NOT either recommend or dissuade in my testimony. I shall only give forth the knowledge that I have aquired.
    This is the Gospel of Rev.Hammer as best as he understands the matter. First I shall describe my altar of vehicular glory:
    2006 Dodge Charger R/T with the Road and Track Option.
    Build date of 11-05-05
    2B3LA53H66H317***
    Trim Level: Y2D1
    Stock Michelin Tires inflated to 35# FlashPaq tire setting is at 27.75
    New air filter
    Mobil 1 synthetic oil
    Full tank of 93octane fuel
    Al observations made with the engine fully warmed
    FlashPaq setting is 91 octane, performance curve, hold gear on manual to redline
    Vehicle unloaded with exception of myself
    Her name is Val and yes, I consider my car to be a female
    No Power Modifications other than a Bassani Catback exhaust.
    Also let me clearly state that I DO NOT OWN A FLASHPAQ. Done was kind enough to let me borrow his and evaluate its effect. There was 1 update installed from the FlashPaq website. Forgive me, but I do not know the descriptor of the update.
    The installation of the modifying software went without complaint or complication. It was straightforward and simple. Upon cranking her exhaust was slightly deeper and more authoritarian.
    Throttle:
    Acceleration was definitely stronger, especially at the bottom end. She pulled substantially better in the 2000-4000 rpm range. My butt dyno was well pleased with the newfound rearward push. I was able to really make her bark the tires at will from a standing start MOST of the time. There seemed to variations in this phenomenon. While throttle response is markedly crisper and more responsive, there seemed to be times that this refreshing crispness faded. This was irrespective of the engine’s temperature. Also, there was a pronounced surge at idle. While the idle was about 150-200 rpm’s higher than pre-flash, the rpm’s surged roughly 200 rpm’s in park, neutral, and engaged. I found that by shutting down the environmental controls, the surge went away. Post return to stock, the surge did not manifest. Cruising was smooth with no surge as hills became laughable. MDS engagement seems to be a bit quicker to come on. Maybe it is perception but I think that the MDS note was more baritone and pronounced. As a side note; when driving in normal versus ESP off modes it seems the ESP was quicker and more strident in engagement with the FlashPaq than stock. In city traffic I was able to literally shoot Val’s muscular hips in and out of traffic with brilliant ease. There was no thinking, just point and push and grin. Other than the surge, I was extremely satisfied with Val’s new lustiness.
    In THIS church, that kind of lust is no sin.
    Shifting:
    Val’s shifting improvement is sweet and profound. Shifts occurred with nearly no hesitance and gear engagement was solid versus what I consider flaccid and vague way it shifted stock. In manual mode she held to redline and bonked the rev limiter with ease. In automatic mode, she held the gear about 500-700 rpm,s higher than stock under normal in city driving. A quick punch of the git-pedal created neat and fast downshifts. I observed 3 instances of double-downshift when flooring it in automatic mode at 60 mph. In manual mode I could tap it into nearly any gear I wanted within reason. I especially liked keeping it in the rpm sweet spot and whacking the loud switch to produce extreme head movement! SWEET! Ahem. Anyway, the shifting in manual mode was just as slick and quick as in automatic mode. On the highway, starting at 60 and hammering it, 140 was only a scant 8-9 seconds away. I do believe that I bumped 150 my dear parishioners but my ticket indicator began a fuss. On twisty roads, ESP off I could get Val to drift so nicely. Half roundies and donuts in a parking lot were unbelievably easy. The only cause for concern is that when shifting in manual at WOT, I had to tap up to 2nd gear around 5700-5800 rpm’s or else the trans would ‘stutter’ and not go to 2nd when manually upshifting. I had to back out of the throttle so that it would shift. This unnatural shifting event would take about a full second to reconcile itself. This did not occur in any other gear and not in automatic mode. This is completely unacceptable!
    Fuel mileage improved by a measured 2-3 miles per gallon. I consider this to impressive to say the least. I drive quite aggressively and Val loves me because I do, so a noted gas savings of this level is remarkable.
    As far as any other matters there were no complaints and everything else seems to be the same as it ever was. I make these postulations:
    I think that a cold air intake would yield provable and visceral power increases.
    Once header issues are worked out, there will also be improvement.
    New rear gears without REALLY sticky tires would be a moot point. If you are spinning, you aren’t accelerating. Once the surge and variant throttle crispness issues are solved, rubber roastage will be really righteous.
    Now if brother Vader will kindly cue up the music, please turn in your hymnals to song 354, George Thorogood’s “Gear Jammer”. Brother Zog will pass the beer plate. Brother 7th will dispense the Holy Fluids.
    And the dead shall walk
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    That was great brother Scott, fine fine job, you the man!.
    jbs123's Avatar
    jbs123 is offline Will race anything for food.
    Nov 2005
    Burke, VA
    Nice.........Preach on Brotha...
    '05 300C / Satin Jade
    - SuperChips
    - AEM Brute Force CAI
    "Oh, You Just have the 5.7" - One of our vendors.
    bipto's Avatar
    New Hampshire
    Great report my friend!
    Now repeat after me...
    "Sorry Don, I haven't seen your Flaspaq..."
    The Iron Mistress Galleries
    R.I.P. Dave...
    Nightshade's Avatar
    Nightshade is offline LX Guru
    Kitchener, Ontariooooo
    Quote Originally Posted by Rev.Hammer
    Build date of 11-05-06
    2B3LA53H66H317***
    Trim Level: Y2D1
    11-05-06?
    How did you manage that? Use the delorian to go forward and then trailer the charger and bring it back?
    FactoryD's Avatar
    FactoryD is online now Gettin' high on the downlow
    Nov 2005
    Phoenix, AZ
    Thee Awsome word of the Rev. Hammer can not be met!
    I was under the impression that the Flashpaq is locked into a VIN number. You may be buying that there tuner thingy.
    bipto's Avatar
    New Hampshire
    Quote Originally Posted by StingK
    Not locked to the VIN, just able to tune only one VIN at a time. He just needs to revert to stock before returning it. LOL - or not... :lol:
    R.I.P. Dave...
    fnkychkn's Avatar
    greasy cardboard box
    great sermon Rev. the congreration is duly impressed.
    have you returned to stock? i thought i read in another thread that flashpaq could only tune one vehicle at a time. if so, did done put his back to stock before you used his tuner? i was under the impression that the tuner retained your stock info in memory while you were running a different program and it could only hold one previous program in memory. i'm not up to speed on the operating characteristics of flashpaq.
    Grelf's Avatar
    Grelf is offline I have no title
    Dec 2005
    Hopewell Junction, NY
    Preach on Rev!!! Praise the Octane and pass the shifter!
    "The Beast"
    2005 SXT AWD Magnum Inferno Red
    graymagnum's Avatar
    graymagnum is offline GRAYMAGNUM
    May 2005
    OLYMPIA, WA
    pick mine up sat, thanks for the report. did you upgrade before flashing? can i run 89oct on a 93 tune?-----is there a god?
    bipto's Avatar
    New Hampshire
    Quote Originally Posted by graymagnum
    No - you'll be a knockin' and a pingin'...
    R.I.P. Dave...
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    Talking
    Quote Originally Posted by Nightshade
    11-05-06?
    Well STINK!!! My typo on that! I need Mr.Peabod's Wayback Machine otherwise!
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    Quote Originally Posted by fnkychkn
    Yes indeedy I returned to stock. Sad but true. I would have to see that surge and trans shifting issue addressed before I approach a purchase solution.
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    Thumbs up
    Val's programming is factory stock with no upgrades or changes. The FlashPaq was updated, tho...
    VERY bad plan about running 89 octane on a 93 tune. At the least you are wasting power and at the most you can damage your engine!
    Yes, there is a God, in fact.. there are MANY..
    Poco Askew's Avatar
    Poco Askew is offline I'm releasing the flying monkeys!
    Feb 2006
    Southern Oregon
    Amen and halalluyah, Rev!
    To see if you'll like it, sometimes you just have to pull your pants down and take a slide on the ice.
    Naked '06 Silver R/T AWD; KW V2s, SC Tuner, JBA catbacks, LED eyebrows, E&G grills (black powder coated), paint-matched
    spoiler, mudguards and fogs, 35% window tint, SilverStars, painted calipers, Lloyds embroidered mats. Looking for new shoes.
