Results 1 to 11 of 11
    johhnyblue's Avatar
    johhnyblue is offline LX Padiwan
    toronto
    Helpppp My Charger Is Dieinggg!:(
    i was changing my spark plugs and before i was driving it it wasn't bad
    but when i took off my intake manifold there OIL inside my intake manifold
    did i blow a gasket or something? holes in my cyder head maybe? theres black smoke coming out my exhaust so i was DEFENITLY burning oil
    so ones i changed my spark plugs i turned the car back on and all it did was start miss firing and electrical signs kept coming on and i was wondering whats going on? did i not part the spark plugs the right space or not do up one of the spark plug wires im just sooo confused and don't know if this is all related to my leaking engine to my intake manifold any input in whats wrong??
    Plum Krazy's Avatar
    Plum Krazy is offline Plum Crazy Daytona #811
    Nov 2007
    Overland Park, KS
    Was the car smokin' before? What lead you to take the intake off? Were the plug wires put back on right?
    12.939 @105.26 mph Hi-Flow Cats, JBA shorties, Reso Delete, C & L, MoPar TCM, TB, 3.06 gears, CMR Toon, Pro Torque 2800
    johhnyblue's Avatar
    toronto
    i wanted to change the plugs because they were over due and im pretty sure the wires are right
    Super T's Avatar
    Aurora, IL
    What engine? If it's a V8, oil in the manifold is common, buy a catch can from Billet Technology, it'll stop. Shouldn't lead to misfiring though. Make sure all your coils are firmly seated on the plugs (or wires, if it's a V6 or an older 5.7L)... Did you use that dielectric grease stuff on the new plugs?
    fnkychkn's Avatar
    greasy cardboard box
    since you had to remove the intake plenum to replace the spark plugs, i'll assume you have a V6. my guess is that you now have a vacuum leak where the EGR tube connects to the intake plenum. the EGR tube-to-plenum seal is most likely cut or out of position (kinda tricky to put back together).
    johhnyblue's Avatar
    toronto
    ya its the 3.5 oh and noo i didnt put that grease thingy on the spark plugs u think thats the resson for it?
    Super T's Avatar
    Aurora, IL
    ^^ Nope, I think Funky's explanation is much better :-)
    fnkychkn's Avatar
    #1 in this diagram is the EGR tube. at the manifold plenum end there is a blue silicone rubber seal and at the valve end there is a gasket.
    SMKG HOT's Avatar
    SMKG HOT is offline Finding the Line - Semper Fi
    FNKYCHKN....You NEVER cease to amaze me. We are so lucky to have you here.
    (I was scratchin my head and your spittin out diagrams..............Da*n, Your a hard act to follow)
    Thanks for just being here Dood.
    Laguna Seca 1.56.24 (4-22-08) 52*F 300C/SRT8 SVS Tuned
    398.91 RWHP / 394.08 (ft/lbs) Torque - (2-21-09) N/A 6.1L Stock Heads & Internals
    Fargo59's Avatar
    hah, i was reading this, and pete beat me to answering it. doesnt hurt that he was here first. the egr tube o-ring is very common. and yeah, will cause all those symptoms.
    johhnyblue's Avatar
    toronto
    yaa thanks everyone its fixed now damnnnn egr tube
