Results 1 to 8 of 8
    HemiMagnumRT's Avatar
    HemiMagnumRT is offline LX Padiwan
    Jan 2012
    Bryan, Ohio
    LX HELP!!! Identifying SRT8 Suspension Parts!!!
    Hello, Tomorrow morning i am going to buy a Rear Cradle with all the suspension And Front Cradle with all the Suspension (Minus the Brembos) from a guy who says that it is all off of a 2008 Charger SRT8,
    Now what i would like to know is how can i be sure it is all from an SRT8 and not an R/T? I know they have different axles, differential ratios, knuckles and so on, But i am not sure by looking at them with an untrained eye i could tell for sure withouth the Brakes being there that they are from an SRT8, now i would think that there has to be some tell tale things to look for that would identify it as SRT8 Parts,
    Any Help Would Be Greatly Appreciated!!!!!!!!
    Thanks,
    Zac
    Meech's Avatar
    Meech is offline LX Guru
    Nov 2006
    Look at my thread of a rear SRT8 cradle for sale, most of the part numbers are listed:
    Parts For Sale 2006 SRT-8 Charger, bought a whole rear clip Brembo to Brembo
    Chubby Pro Sways, BCR Coil Overs, Jay's Camber Arms,Speedlogix Bump steer kit/Wretched-Pedders Lower Control Arms BlueTops/CL63 Rear Cooler/JoelVan Rad/PS Cooler/PO Cooler/SRT Max Plus Cam/Forged Push Rods/600HP Half Shafts/Magnaflow Hiflow Cats, Corsa Cat back/ Staggered Satin Vipers wrapped in Vredestein Ultrac Sessantas 275/40/20's (front) & 315/35/20 (rear). HHP Installed Wavetrac/NASCAR Cooling Ducts to ET1970 3" Brake Plates/TI (Track) Backing Plates/ AERO Hood/Naturally Aspirated Force Flow Legmaker CF-F-III STU-HHP Modified HemiTuner DynoTune:
    Diablo 93 Octane 433 RWHP/425 RWTQ
    SuperFrawgie1361's Avatar
    SuperFrawgie1361 is offline formally 2intenz
    Nov 2008
    Panama City, Florida
    actually a R/T and a SRT rear cradle is the same, only difference it the rear differential is 215mm 3.06 gears (SRT) verse 210mm 2.82 gears (R/T), which can be identified by 4 flange drive shaft mounting flange (SRT), the coil springs, the shocks and the sway bar diameter .... every thing else is the same.
    Hemi Registry #1348 SuperFrawgie 1361
    fnkycld's Avatar
    fnkycld is offline Yes that low without air bags.....
    Jun 2009
    Anaheim, CA
    The rear subframes are the same for all models levels. The only difference is between the AWD and the RWD. All the suspension arms are the same as well. The only difference would be the knuckles and the gear ratio should be stamped on the differential. The axles will be larger as well.
    Need a tire calculator? Use this one.
    Plenty more pics on my Facebook page
    Nov 2008
    The front, the rack and pinion, strut tensioner, steering knucks, struts, sway bar, coil springs, ALSO IF IT WAS A AWD VECHICLE LOTS WOULD BE DIFFERENT
    Hemi31's Avatar
    Plattsburgh,NY/Lorain Oh
    Quote Originally Posted by SuperFrawgie1361 View Post
    No...they absolutely are not! Bilstien shocks will be on the SRT ,more progressive springs,a thicker front bar, The tension struts on the srt have a different bushing, steering rack is different from base r/t,same as daytona and r&t.
    RIP NHDave
    MAGFX is offline Nevermind my mind!
    Dec 2005
    Arizona
    You will be fine, but actually, the rear cradle itself is different from year to year and lx model to lx model (i.e. 300 to Charger). I'm not sure if there were differences from an RT to an SRT. Some of the structure of the cradle have holes in it or is not boxed in. As far as I know, the '09's and newer have the improved design.
    Like what was said above, look for the 4 flange driveshaft and diff input shaft setup for SRT.
    Also, you might have some pictures taken and post on here. Good luck.
    I smile because i have no idea whats going on.
    My friends call me JONN (usually).
    Nov 2008
    maybe you miss understood what I said, everything you said is what I said is different from a R/T to A SRT, I did miss the tension strut,
