Results 1 to 15 of 18
    Joe@402Motoring's Avatar
    Joe@402Motoring is offline Resident Audio Head at 402 Motoring
    Diablo u0101 problem code!!! HELP!!!!!!
    went to start the car, wouldnt start on first try. second time it started and got a u0101 code. car now shifts hard, wont shift out of first, and went into limp mode. tried to reload stock tune back in and it wont let me. says it couldnt remove quick adjusts. any suggestions?
    We sell custom wheels! Please ask me before you buy from someone else! Call 1-877-BLING - IT
    402 Motoring Audio Department now open!
    Most Brands of Head units, Nav systems, speakers, subs, amps. We'll beat Crutchfield pricing!!
    Click here to see my work:
    http://s24.photobucket.com/albums/c4...y/402%20Audio/
    Please visit our Website
    www.402Motoring.com
    Peter Parker's Avatar
    Peter Parker is offline I just wanna go fast...
    Feb 2008
    Smashville, TN
    Lost communication with TCM, might want to check those connections/dielectric grease. Otherwise the TCM may be toast??? Any experts?
    Lopey: 6.1L N/A Modified / 3700lbs 473rwhp/439tq ~ Quickest ET : 11.152/117.5mph, 1/8 - 7.0/99.56, 1/4 Trap - 126.15mph <~ Sold
    R.I.P. Lou1355
    Fargo59's Avatar
    U0101 is a loss of communication with TCM fault. try a battery disconnect or fuse 11 reset. is the PRNDL displaying the proper gear in the cluster?
    all connections are good.
    www.402Motoring.com
    Feb 2008
    Smashville, TN
    fargo's the man...
    R.I.P. Lou1355
    Quote Originally Posted by fargo59 View Post
    it shows the proper gears but wont let me autoshift
    www.402Motoring.com
    fnkychkn's Avatar
    greasy cardboard box
    check TCM harness. seen one rub through against park brake mechanism that gave me the same code.
    check all the wires, they are fine
    www.402Motoring.com
    sound&security's Avatar
    sound&security is offline NOT MADE IN CHINA!
    Aug 2007
    FT LAUDERDALE
    JOEY-ON THE PASSENGER SIDE SHOCK TOWER between the top of the shock and the fuse box there is a group of 18 gauge ground wires grounded there on one copper eyelit. check to see if that ground is loose or any broken wire braids.
    IF those look good and are tight and undamaged-then check the 2nd ground wire on the back side of the same shock tower between the fire wall and the shock. LARGE ground blue/gray color is the motor ground but there are 2 14 gauge grounds there also. make sure they are intact also
    Think about how stupid the average person is..
    Then realize half of them are dumber than that
    fnkychkn's Avatar
    how did you get the code? diablo? key dance? starscan/starmobile?
    is that the only code?
    i got it from the diablo
    www.402Motoring.com
    fnkychkn's Avatar
    you might need a starscan/starmobile to see if any other modules are affected/storing codes.
    did you try a PCM reset as fargo suggested?
    pulled the neg on the battery for the night. will see how things go tomorrow morning
    www.402Motoring.com
    dpshook's Avatar
    dpshook is offline LX Padiwan
    Feb 2008
    lol i get this every time use the predator, then when i restart the car it goes away
    I eat through end links like candy bars!
    JarZ's Avatar
    JarZ is offline Ole sad på en knold og sang
    Union County, NJ
    Joey, did you get it fixed?
    2005 Bright Silver Dodge Magnum R/T - Inertia 5.7 heads/Spartan cam/JBA headers/AFE II/BB Fat Pipes/402 Motoring spoiler/tinted tails
    2006 Brilliant Black Dodge Magnum SRT-8
    5.7L & 6.1L Hemi Registry # 856
    JarZ@Inertiamotorsports.com
    Please call us at 512-964-7724/862-215-4668 or send me an email for any questions about our products.
    Find us on Facebook Or @inertia392 on Twitter
