Thread: 6x9's?
    ManiaCharger's Avatar
    ManiaCharger is offline LX Padiwan
    Dec 2005
    6x9's?
    ---1--- This is what I plan on doing:
    (1) New HU
    (2) Use the Peripheral adapter coming out to use factory amp and factory BA 6-speakers
    (3) Put two 12's in the trunk
    ---2--- Will the 6x9's on the rear deck be affected by those subs running at 1200 watts?
    ---3--- If so, can I remove those 6x9's on the rear deck, and then that factory CANbus amp still work properly (simply leaving 2 channels open), or will it cause problems in the CANbus's programming?
    THANKS!
    '06 Charger SXT - Blizzack, Leather Seats (Slate Gray)
    THE EGG!!!
    THE BLACK
    BEAST
    Mighty Noid's Avatar
    Mighty Noid is online now time to paint the car soon!!!
    Aug 2005
    SoCal
    Quote Originally Posted by ManiaCharger
    (1) New HU
    THANKS!
    Wondering how many threads and how many questions you are going to ask, which are basically the same one before you take yourself to a stereo shop or just do it yourself already?
    Thank you Bigal470
    RTjunkie's Avatar
    RTjunkie is offline Geek / Audio-Whore / Car-Whore
    Feb 2006
    Orlando, FL
    The subs should not apply enough pressure to damage the 6x9's in the rear deck. There should be plenty of places air can pass into the cabin of the vehicle without affecting those.
    I had a Lumina previous to my Charger which had minimal places for air passage back into the cabin, all the while running a 2000W amp with a 12" and two 10's, never an incident.
    -Nate
    2006 Silver Steel Charger R/T with R&T-PG
    HEMI Registry #508 | Florida LX Club
