Results 1 to 14 of 14
    OA-5599's Avatar
    OA-5599 is offline Vanishing Point
    Denver, Colorado
    working with the felxible bumper
    Advice needed... I have a killer front end in mind, but I must be able to work with the flexible front facia. Can I use a more rigid fiberglass on top of it? SHould I just re-mold the whole piece in fiberglass? I assume any kind of bondo will flake off because of the flexible poly. What can I use to mold and shape it>?
    Thanks
    2005 Magnum R/T; Hemi Registry #178
    Vortech SC, Dynatech Longtubes, Cats, Aeroturbine Exhaust, Body Mods
    NC-SXT's Avatar
    NC-SXT is online now purveyor of fine custom grilles
    NC Coast
    I would ask Ernie from Avon Wheels
    WWW.DodgeMagnumGrille.com
    OA-5599's Avatar
    Denver, Colorado
    Ernie, remember how I got you started with the body colored headlights? Can you help me out?
    bigjim's Avatar
    bigjim is online now Damn Fast Grandpa!!
    Oct 2004
    LaFargeville, NY / Bolton, ON
    Any good body supply shop will have several choices that stay flexible and stick like you wouldn't believe!! Go for a walk or ride and talk to the supply shop, they WILL help. PS, it ani't cheap but does exist.
    05 Magnum RT 5.7 (Member ALLPAR.com 200,000 mile club) Rockinsrt8 shifter, Hemi reg #164 266,666 miles (c'mon John, I slowed down! NOT)
    Sidewinder, 6.1 pushrods, springs, underdrive pulley, SRT exhaust (donated by NHDave) headers to tips, all installed by Hemi31! Quaife, certain Pedders bushes installed, SRT Nivomats and Bilsteins. Police rotors and pads. HIR. Predator. LMI.
    1:19 NJMP Lightning
    1:45 Mosport
    grinner's Avatar
    grinner is offline ModdinArt.com
    Dec 2004
    stl
    I recomend 3M Automix. You can get it at auto paint stores. It remains flexible so it won't crack like fiberglass will. In certain spots, fiberglass will work fine but anywhere it will still flex, a flexible filler should be used. This stuff works as a 2-ply epoxy. Not easy to work with and not easy to sand. Good stuff tho. Thats what I used on my front end.
    OA-5599's Avatar
    Denver, Colorado
    Grinner, BigJim, what kind of material can I use to fill in/build up large areas? For example, if I wanted to remove the bumper channels (fill them in) and fill in the lower openings - going for a really smooth look - is there some kind of poly sheeting, then fill and finish with the Automix? Likewise, for the tail, the photoshop renderings of the body colored tails has me going, but why paint them when I can just remove, replace with fiberglass or some other material, and use the LED strips (and killer backup in the liftgate handle). I have done some artistic and industrial casting, so the tails are going to be easy, but I am very intimidated by the flexible front.
    I am going to SO HOMER this up!
    grinner's Avatar
    Dec 2004
    stl
    I used bondo spreaders and a paint stick to build a wall to build the epoxy on top of. Turned aout awesome.
    Here's a thread that covers it in depth with some video and some pics:
    lil nose job part 1
    OA-5599's Avatar
    Denver, Colorado
    Thanks Grinner, looks like I can be very creative with the backing materials. Killer look on yours now, as many have said; very aggressive. Pity the fool mini or civic that gets in the way!
    OA-5599's Avatar
    Denver, Colorado
    here is what I have in mind:
    I am not a PhotoShop person, so please do not get down on me for the rough chop, I am using version 5.5 that was bootlegged nearly ten years ago. The look I am trying to achieve is one that tightens up the front end a bit, and pays respect to the DNA:
    Mine has body colored headlamp assemblies, and I will have a grille with a circle punched flat black pattern, which would be matched in the lower opening and the area around the driving lamps.
    I am set on doing this, just need to find the right materials go at it!
    COLORADOMAGNUM's Avatar
    COLORADOMAGNUM is offline I'm not speeding......I'm qualifying
    Lakewood, CO
    That is sick. I hope you get this done, John. That is an awesome look!!!
    2005 Magnum SXT AWD - Inferno Red
    Mods: Diablo Predator, JBA headers, Zoomers single exhaust, K & N Aircharger, KW coilovers (variant 2's), 402 Motoring tinted tails, lots of Billet Technology stuff, real walnut dash kit, MOPAR on-dash nav, NC-SXT original honeycomb grille, Jina's Embroidery custom headrests.
    boggart's Avatar
    Pittsburg, KS
    I don't like it. Makes the "bumper" look too big.
    OA-5599's Avatar
    Denver, Colorado
    another perspective:
    less aggressive? Audi?
    grinner's Avatar
    Dec 2004
    stl
    wonder what that'd look like in person with the bumper seperating the grilles painted flat black. Like one bigass opening?
    May be too much.
    OA-5599's Avatar
    Denver, Colorado
    I just got the car back from the dealer, 10 days, stuff done, and will start on the front this weekend. The more I look at the photchop, the more I like it.
