Page 1 of 3 123 LastLast
Results 1 to 15 of 38
Thread: wire help
    STAGE 3 R/T's Avatar
    Jan 2006
    Argyle, Tx
    wire help
    Ok in installed my lsd doors.... Lastnight my front passenger window was workin fine. Now nothing. I checked my wires and connections all is good. Is there a fuse for each window?
    My other windows are working fine as well. Ohhh my window lock option isnt working. Maybe I jacked those two up some how? But I did each wire seperatly...
    Is it possible the window lock might have something to do with that one window not working since that options is now not working?
    Where do I go to find what each wire is? i.e. wire color and so on...
    I drive a 2005 Dodge Magnum R/T...
    Thanks
    hh
    Jan 2006
    Argyle, Tx
    fnkychkn's Avatar
    greasy cardboard box
    i'll get back to you in a bit. just replied to your post on another thread.
    Jan 2006
    Argyle, Tx
    got ya thanks!! seen that post and i am standing by for your reply!!!
    fnkychkn's Avatar
    OK, let's start over. you're confusing the hell out of me. :?
    what i understand so far: (please fill in the blanks)
    you installed LSDs last night and all was working well.
    this morning the _________ window did not work from the ________ switch.
    also the ______ lock button didn't work.
    i will post a link to this thread from the other one.
    Jan 2006
    Argyle, Tx
    sorry about that!
    this morning the front passengers window did not work from the either of the front (drivers or pasengers) switch.
    also the window (for the rear windows) lock button didn't work.
    Ghostface Mag's Avatar
    Ghostface Mag is offline Vendor/Shop Car for HHP Racing...
    Jun 2005
    "Somewhere in MD. so you can HATE on me"...
    Check Us Out Online & Contact Us @ 1-888-894-1115
    HHP/B.E.S Forged 8.8:1 HHP Stage 4 Cam HHP Race Grade Heads ProCharged(F-1D) Zex Meth & CryO² Paramount NAG1
    Sponsors B.E.S Racing STSuspension AfterFX Kooks Headers Builder Bill
    fnkychkn's Avatar
    did you remove the wires from the connectors at the door jambs?
    since all was working ok last night (after the install), i must assume that all wires are in the proper connector slots. perhaps one of the pins wasn't completely inserted and has since pushed out.
    fnkychkn's Avatar
    here is a pinout of C301 passenger side connector (door half):
    cavity/circuit/wire size & colour/application
    1-
    2 C16 20DB/GY
    3 A913 20RD/GY (EXCEPT BASE)
    4 Q26 14OR/GY (BASE)
    5 G74 20VT/WT
    6 P37 20LG/TN
    7 G160 20VT/LG
    8 M24 20YL/WT (EXCEPT BASE)
    9 D55 20WT/OR (EXCEPT BASE)
    10 D54 20WT (EXCEPT BASE)
    11 X202 18DG/VT
    12 X292 18DG/YL
    13 F880 20PK/DG (EXCEPT BASE)
    14 Z911 14BK/WT
    15 Q15 14OR/LB (BASE)
    16 P303 20TN
    17 P72 20TN/GY (EXCEPT MEMORY)
    18 P74 20TN/OR (EXCEPT MEMORY)
    19-
    20 P392 20LG/DB
    21 Q16 14OR/TN (BASE)
    22 F881 14PK
    23 P76 20TN/LB (EXCEPT MEMORY)
    24-
    Jan 2006
    Argyle, Tx
    i removed the connector last night then reconnected it. i extened all the wires by using the plastic connectors with the center sodder capable.
    when i get home from work, i am gonna go back and make sure every wire is correct. do you have a ref for what wire to be on the look for i guess the color of the wire????
    thanks again for your help!
    Jan 2006
    Argyle, Tx
    will double check!
    1-
    2 C16 20DB/GY
    5 G74 20VT/WT
    6 P37 20LG/TN
    7 G160 20VT/LG
    11 X202 18DG/VT
    12 X292 18DG/YL
    14 Z911 14BK/WT
    16 P303 20TN
    19-
    20 P392 20LG/DB
    22 F881 14PK
    24-
    fnkychkn's Avatar
    C300 (driver's side door harness connector) looks the same as C301.
    1 Q411 14OR/WT
    2 C16 20DB/GY
    3 A913 20RD/GY
    4 Q412 14OR/LB
    5 G75 20VT
    6 G167 20VT/LB
    7 G161 20VT/DG
    10 Q26 14OR/GY (BASE)
    11 X201 18GY/VT
    12 X291 18GY/YL
    13 F880 20PK/DG (EXCEPT MEMORY)
    14 Z912 14BK/OR
    15 Q15 14OR/LB
    16 P1 20TN/LG
    17 P112 20TN/OR (MEMORY)
    18 P114 20TN/WT (MEMORY)
    19 Q611 14OR/GY
    20 P393 20LG
    21 Q612 14OR/DB
    22 F881 14PK
    24 Q16 14OR/TN (BASE)
    Jan 2006
    Argyle, Tx
    i have not touched the passengers side door yet. only the drivers side door has been touched. hope this will help too!
    fnkychkn's Avatar
    pay particular attention to Q15 circuit (window lock). it is a 14 guage orange/light blue wire and should be in pin 15 of both connectors.
    also check Q16 circuit (R/F window switch). it is a 14 guage orange/tan wire in pin 4 of C300 and pin 21 of C301.
    also check Q26 circuit (R/F window switch). it is a 14 guage orange/grey wire in pin 21 0f C300 and pin 4 of C301.
    fnkychkn's Avatar
    Quote Originally Posted by hawaiiHEMI View Post
    well, that narrows it down a lot. disregard everything about C301 (passenger side).
