Results 1 to 13 of 13
Thread: What's this?
    ZMagnum's Avatar
    Tucson, AZ
    Question What's this?
    Is this a cold start injector? Vacuum line for something?
    MidnightSXT's Avatar
    MidnightSXT is offline LX Guru
    P.G. B.C. Canada
    Vacuum line for..something.
    JOKERCANTSMOKE-EM's Avatar
    JOKERCANTSMOKE-EM is offline If you gotta go.....go with a SMILE
    Aug 2009
    Sioux Falls SD.
    Pcv?
    Quote Originally Posted by MattRMagnum View Post
    Few things in life scare me into behaving like Charger cop cars. I maintain an irrational belief that, rather than ticket me, any cop who gets out of such a car is going to just beat me.
    The 2012 Dodge Charger Police Package: To Protect, and Serve Your Ass to You on a Platter.
    170degree thermostat
    frankentake
    flowmaster exhaust/deleted suitcase and resonators
    Junior's Avatar
    Junior is offline LX Guru
    Phoenix
    It's a vacuum line, Mark, but I forget for what exactly. When we did the shaved manifolds, some guys routed them underneath (Hammer did his in rigid tubing). I bought some rubber hose that fit over the diameter of the tubing itself, cut little nipples from the existing tube, and ran hose underneath the coilpacks, sorta.
    ZMagnum's Avatar
    Tucson, AZ
    Quote Originally Posted by Junior View Post
    Cool, thanks. It would certainly look better if it was routed differently.
    89grand's Avatar
    89grand is offline LX Guru
    Phoenix, AZ
    I always wondered what that was too. It looks almost like a spark plug wire even though I knew it wasn't that.
    2000 Jeep Wrangler
    1966 Dodge Monaco 500
    Junior's Avatar
    Phoenix
    If you follow it back, it routes behind the manifold to a canister mounted on the passenger side firewall. I'm not sure what it is or what it does, but the plastic tubing will slide out of the rubber boot pretty easily, and you can see it's just tubing.
    Super T's Avatar
    Aurora, IL
    I think that vacuum tube is for the evap system (emissions).
    Bryali's Avatar
    Bryali is online now Getting blown and hooked on meth...
    Apr 2006
    Upstate, NY
    Maybe it's a vacuum secondary for the warp drive? LOL
    2005 Magnum SXT: Fiberglass Hood, smoked LED tail lights, billet grille, Airaid CAI, Magnaflow Cat-Back, Polk Audio speakers, BT Catch Can, Debadged, Demolded, Predator 89 Tune, Ported & polished lower manifold, TB, and Jet Coated valve covers, front & rear R/T sway bars, longtube headers
    To Do Still: tint the front windows, wheels and rubber, and 1 MAJOR build going on right now...stay tuned...
    --new image coming soon--
    glhs837 is offline Power With Control
    Very Southern Maryland
    Ah, that triggered a Neon meory that might explain it. Sounds like tis the source of vac for the NVLD, or Natural Vacumm Leak Detection system, or whatever its called on this car. See, if thats what it is, it supplies a vac source to the fuel tank. A sensor monitors that vac, and if it goes away, it triggers an EVAP fault code.
    Most common cause of this is the infamous "Did you tighten the gas cap"?
    ZMagnum's Avatar
    Tucson, AZ
    So what happens to this if you are running a blower? It's not a vacuum anymore.
    In the Neon SRT-4, this line was actually on the far side of a venturi fitting, so even in boost, there was vac. Even so, this isnt a constant thing, and your still drawing vac enough that it shouldnt matter. If you get worried, toss a check valve in there so it can only draw vac from it, not put pressure into it.
    1fastsedan's Avatar
    almost Mexico, CA
    Quote Originally Posted by ZMagnum View Post
    Haven't had a problem and my blower has been on almost a year and a half. It probably just not under boost long enough and then evacuated right away when you're back under vacuum.
