Results 1 to 9 of 9
    E55 KEV's Avatar
    E55 KEV is offline LX Padiwan
    Mar 2004
    Washington D.C.
    What Are Wheels Specs?
    Can anyone confirm? A D-C employee on another site stated that this as LX chassis wheel specs.
    Center Bore = 72mm
    Bolt Pattern = 5 x 115mm
    Offset = 24mm
    The 300C and Magnum RT alloy wheel are 18 x 7.5 but those stated wheel specs bother me because that bolt pattern is used on GM and Cadillac cars. I was hoping for a wheel spec similar to Mercedes like used on the Crossfire with:
    Center Bore = 66.56mm
    Bolt Pattern = 5 x 112mm
    Previous bolt pattern on Chrysler and Dodge cars is 5 x 114.3. That 5 x 115 pattern will severly LIMIT the wheel choices. :x
    • My Website - www.E55AMG.com
    • 2002 Mercedes-Benz E55 AMG
    • 2005 Dodge Magnum RT Hemi
    • 2005 Chrysler 300C Hemi
    DSMLVR is offline LX Padiwan
    Feb 2004
    High Ridge, Missouri
    Well, that would be great if you had some Crossfire wheels you wanted to use. IF it is true that the specs match GM, think of the multitude of wheels out there you can customize with. :lol:
    2001 Dodge Grand Caravan Sport
    2004 Chrysler Pacifica AWD
    E55 KEV's Avatar
    Mar 2004
    Washington D.C.
    Quote Originally Posted by DSMLVR
    I see very few 5-115 bolt pattern wheels. Perhaps, I am coming FROM a Import frame of mind but 5-115 is hard to find compare to 5x112 Mercedes & VW, 5x120 BMW and 5x114.3 every Japanese make. If you go to Tire Rack or Discount Tire and look up wheels for a Cadillac Sedan you will get few and the others have much more.
    I am planning my mods now and I will be changing my Magnum OEM wheels ASAP to 19 or 20" and I have been looking for wheels in 5x115 and I am dissappointed in whats available. I was hoping that the LX cars used 5x112 so I can use some Mercedes Tuner wheels like AMG, Brabus, Lorinser, etc.
    YB Normyl is offline LX Newbie
    Feb 2004
    Planet LX
    I can't confirm 5x115 but I do know we have a rolling calibrating jig for wheel alignment calibration and the jig hasn't changed but it's now sitting on LX rims. I've been told it's the same as the LH's, I'll try to find out for sure.
    MagnaCharger
    DMAG's Avatar
    Feb 2004
    New Yawk
    Thanks YB...this seems to be one of the biggest questions everyone seems to have. I'll add it to the FAQs database as soon as we know for sure.
    Anthony
    E55 KEV's Avatar
    Mar 2004
    Washington D.C.
    Looks like the bolt pattern may not have changed? See my thread:
    http://www.dodgemagnum.net/phpBB2/vi...hp?p=2054#2054
    Feb 2004
    Planet LX
    I'm still waiting for documention on the bolt circle.
    MagnaCharger
    Feb 2004
    Planet LX
    LX Wheel Specs
    115mm is the bolt circle for the LX's,
    the center hole diameter of the alloy wheel at the hub is 71.55mm,
    the contact area of the bolt circle to the hub is 149mm,
    the backspacing is 5.25 inches,
    the torque for the lug nuts is 160 N-m
    MagnaCharger
    DMAG's Avatar
    Feb 2004
    New Yawk
    YB to the rescue!
    Thanks!
    Anthony
