Page 1 of 3 123 LastLast
Results 1 to 15 of 36
    bigkevin20's Avatar
    bigkevin20 is offline I like them natural and heavy!!!
    Oct 2004
    PA
    What problems are you having with your LX?
    I wanted to get all my complaints in one post. Maybe you can give me advice and add to the list.
    1. Lost Cruise Control after 22 install did not insert pressure sensors.
    2. Intermittent check engine Light. Code P0340 and P0335 Crankshaft sensor and cam shaft sensor.
    3. Auto headlights turn off while driving at night about once a month, I then turn to manual lights till I restart which fixes the problem.
    4. Some times my auto window roll up or down stops working, and it just stops when you let go. Then the problem goes away. I had my car going on 6 months now this has happened at least 4-5 times.
    And thats all I can complain about, every thing else I love. Im making an appointment for my 3rd oil change and every thing mentioned above pretty soon. I all ready put 10'000 miles on my car since April.
    HEMI!, Diablo Predator CAI tune SOLD, "GIGANTICAI" CAI, Blastin Bobs 7db , 22" 4inch LIP Velocity VW700 Rims on 265/35s SOLD, Chrome Grill, mirrors, pillars, handles and bumper inserts. Clear LED tails, 15" RE SX Sub, 7" Touch screen Navi, Ipod Control, TV Tuner, LED floor lights and license plate light strip, Reverse Camera,. FTP
    The "Giganticai"http://www.lxforums.com/board/f74/check-out-my-new-gigantic-diy-cai-112170/
    The Mag http://www.lxforums.com/board/f74/hear-my-baby-first-time-pics-75308/
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    well #3 and #4 sound like (to me) you have a loose battery connection.
    both features stop functioning after battery disco..
    and these cars are known to come off the assembly line with loose fuses and battery cables.
    as for my problems..
    in 14 months I have had my airbag system repaired 9 times.
    5 new clock springs
    7 new wire harnesses
    4 new connectors
    2 airbags (steering wheel)
    1 new steeering column, including the electric telescoping motor and rack and pinion linkage.
    3 new sun roofs (track, motor, rain guard, and air deflector)
    new FCM
    new TCM
    new CCN
    new Cluster
    new rack and pinion / tie rods
    new window regulators on all four doors.
    3 new Navigation units (one for jammed CD changer, one for Joystick issue before repair found, and one for LCD going out)
    all in 14 months of ownership..
    however my motor and tranny are solid, no issues at all with either in 54K miles.
    vinny68's Avatar
    vinny68 is offline VINNY68
    May 2006
    Central Illinois
    I had to have my radio replaced because it wouldn't work in the cold but that's it.
    Phil Hunter is offline LX Padiwan
    Aug 2005
    Temecula
    I've had two problems with my early '06 300C, both well known.
    1. transmission O ring leak
    2. Left rear power window quit working.
    Both fixed under warranty.
    Phil
    traction seem to be my biggest issue. i may have it solve.
    bigkevin20's Avatar
    Oct 2004
    PA
    Quote Originally Posted by Mr. iNCREDIBLE View Post
    5 new clock springs
    4 new connectors
    new FCM
    new TCM
    new CCN
    new Cluster
    I will have check the battery, but DAMN!!!! All that I dont feel that bad any more.
    The "Giganticai"http://www.lxforums.com/board/showthread.php?t=112170
    The Mag http://www.lxforums.com/board/showthread.php?t=75308
    CrAzYMoPaRGuY's Avatar
    CrAzYMoPaRGuY is offline The Chryco psycho......
    Locked in my Canadian garage
    We've had our Magnum R/T for six months, my ONLY problem is I don't get enough seat time.
    It's my wife's car.
    NC-SXT's Avatar
    NC Coast
    Reverse has gone out on my tranny. (36K miles) . But thats all.
    WWW.DodgeMagnumGrille.com
    OregonR/T's Avatar
    OregonR/T is offline LX Padiwan
    Medford, Oregon
    Only a few minor things so far for us (06 Mag RT):
    "O" Ring replaced under warranty for the tranny
    Random los of the power windows auto up and auto down. Fix this using the method in the manual.
    Left rear power window motor stopped working. Replaced under warranty.
    O2 sensor had to be replaced. Kept throwing codes ( I can't remember which ones). Also replaced under warranty.
    The one thing that worries me a little bit is these things, although small warranty items, happened when the car was relitively new. What kind of things are going to happen when the car starts to get up there in miles and the warranty runs out? Oh well at this point I am not going to worry about it and I am going to keep enjoying the best and coolest car that I have ever owned!!!
    06 Silver Magnum R/T
    Devino 430 Adana 22" Rims/Hankook 265 35 22
    K&N Typhoon CAI
    Billet door lock pins, Billet headrest spacers
    Ultimate pedals, Billet Technologies under hood goodies
    http://s119.photobucket.com/albums/o135/OregonRT/
    Tbird100636's Avatar
    Tbird100636 is online now Master ASE Certified NON-Chrysler Tech
    Braintree, Massachusetts
    Exclamation
    Quote Originally Posted by bigkevin20 View Post
    And thats all I can complain about, every thing else I love. I'm making an appointment for my 3rd oil change and every thing mentioned above pretty soon. I all ready put 10,000 miles on my car since April.
    I'll address these.
    1.) Your tire sizes need to be programmed with a tuner, as the StarScan/StarMobile only have stock sizes.
    2.) You may have a bad crank sensor or a bad cam sensor. The diagnostic procedure has you check the signal with a lab scope on the DRBIII scanner or on a graphing multimeter. It also has you check the basics (5V supply, signal circuit, ground). Either sensor can affect the operation of the other. If you have a long crank time it's usually the cam sensor. But... I've yet to see a cam or crank sensor issue on a 5.7L. It was more common on a 2.7L or 4.7L engine, but again... the fuel system works the same way on a 5.7L.
    3.) Purely a guess, either a bad light sensor or a bad headlght switch. Any A/C issues???
    4.) TSB 08-011-07 Rev. A covers the Auto up/down windows issue.
    www.ramtruckforums.com
    Exclamation
    Quote Originally Posted by OregonR/T View Post
    If you owned a Sprinter, it would be something to worry about!!!
    ezridr95's Avatar
    ezridr95 is offline Air bag test dummy....
    Dec 2006
    Costa Mesa, CA
    2 new torque converters first at 20,000, second 200 miles later, now rear window regulators at 35,300. Other wise its been good.
    Rockinsrt8's Avatar
    Rockinsrt8 is offline Custom LX Accessories
    Charleston,SC
    nothing broken at all, best car ever! 2 TSBs done rotors and rad flush, thats it! And to think I was reluctant about buying Chrysler.
    Have had a vette that had the motor pulled when 3 days old and a Suzuki bike, intruder 1400, that knocked from mile 300 till they finally agreed to work on it (after it was burning a quart of oil in 10 miles, 2,800 on the OD) then refused to cover it ,leaving me holding the bag. Dealer returned it in pieces with dented tank etc. to boot. Suzuki corporate thought it was funny. To this day if anyone recites that old bit about Jap products being built better, I slap the taste out of their mouth
    www.qualityrockers.com/PistolGripShifter.htm
    2006 300c SRT8
    388.50 RWHP (naked)
    387.46 RWTQ
    100 shot Zex,Kenne bell boost a pump,Billyboat catbacks, Preditor,
    AirHammer CAI,Dmh E-cutouts,DC strut bar, Hotchkis sways,315s+275s Vredesteins on Giovanna Dalars
    OcalaHemi's Avatar
    OcalaHemi is offline LX Guru
    Ocala
    06 Magnum Build date 10/2005. Bought 11/2005, I have 26,000 miles have had no problems other then a squeeking rear brake pad. I noticed most of these posts are in the north and west. Can we tell by the vin where it was built?
    300 (SRT) front, MSRT rear bumper, shaved rear wiper, 402 rear spoiler, RK/Sport raised hood, Grip grille, Boss 304 18" wheels, 245/55 BF Goodrich tires, painted coolant tank (402), painted engine cover and ABS cover, LED tail lights and side markers, LED lighting in engine bay, MagnaFlow High Flow Cats & exhaust, Vortech V-3 S/C, Vortech Predator tuned, 180 Tstat, X-treme Duty Radiator, Billet/Tech engine dress up, B/T oil catch can, Painted radiator cover! A big Thanks to Rod Burton who did the conversion & S/C install.
    Magnum Power's Avatar
    Magnum Power is offline Hypermiler
    Dec 2006
    Upstate, New York
    My 06 RT AWD has had three wheel bearings replaced in 16K miles, the horn , horn pad, and wire harness replaced, and now the grand daddy of them all is the tires are bad and need replacing. The stealership won't deal with it they have pushed it off to Coni to deal with. I am still in the process of getting a straight answer from them, I have thought about getting a lawyer, and maybe going to the media
    "Heimes Oppugnamus Et Montes Superamus"
