C2115-DYNAMICS SENSOR SUPPLY VOLTAGE HIGH
For a complete wiring diagram Refer to Section 8W</B>.
- Upon ignition on, prior to switching the (G4) Dynamics Sensor Supply circuit power on.
- Set Condition:</B> If the Anti-Lock Brakes Module detects voltage on the (G4) Dynamics Sensor Supply circuit when the circuit's power is turned off.
Possible Causes</B> WIRING HARNESS, TERMINAL, CONNECTOR DAMAGE (G4) DYNAMICS SENSOR SUPPLY CIRCUIT SHORTED TO VOLTAGE ANTI-LOCK BRAKES MODULE
</B>1. VERIFY DTC IS ACTIVE </B>
Turn the ignition on.
With the scan tool, read and record ABS DTCs.
With the scan tool, read and record Environmental Data (EV Data).
With the scan tool, erase ABS DTCs.
Cycle the ignition switch.
With the scan tool, read ABS DTCs.
Does this DTC reset?
Yes
2. INSPECT RELATED WIRING HARNESS, TERMINALS, & CONNECTORS </B>
Turn the ignition off.
Check all related wiring for pinched, chafed, pierced, and partially broken wires.
Check all related connectors for broken, bent, pushed out, and corroded terminals.
Were any problems found?
Yes
3. CHECK (G4) DYNAMICS SENSOR SUPPLY CIRCUIT SHORT FOR A SHORT TO VOLTAGE </B>
Disconnect the Anti-Lock Brakes Module harness connector.
Measure the voltage of the (G4) Dynamics Sensor Supply Circuit.
Is the voltage above 0.2 volts?
Yes
5.7L Hemi Registry # 00814
