Results 1 to 4 of 4
    fullofit_'s Avatar
    fullofit_ is offline katie, princess of Rue
    Nov 2006
    tempe az
    what is hal doing?
    I was fooling around with stuff, and this is what I did, I don't know what Hal is doing for sure, but I think it's a system check.
    First I turned off the ignition with the radio on.
    Then while depressing the trip reset I turned the key on until the radio cut out but stopped before the started engaged. I held it on after all the bells stopped then there was one more bell and I let go of the key and the trip reset. The screen in the speedo displayed my software version and a PN.
    The speedo and tack jumped up then dropped down in equal increments. All the warning lights were displayed. Then there were these three bars in the screen from long to short one after the other dropping down. The bars ran three times then there was a message that said done.
    Ok so just what have I "done"
    all the best,
    full
    crazy_luck's Avatar
    crazy_luck is offline I know where Hoffa is...
    Belle Plaine, MN
    Sounds like you ran the "instrument cluster test"
    fullofit_'s Avatar
    Nov 2006
    tempe az
    ok
    cool is that the normal way to do it?
    OK, I found lots of threads on this stuff, this place truly rocks.
    now quit laughing at me and drive on,
    full,
    GR8DODG's Avatar
    GR8DODG is offline Just gettin started..............
    Jun 2006
    Belfair, WA
    I'm gonna have to dispatch the nuclear response team on this one.......
    And playing innocent won't get you outta trouble on this!
    GR8DODG
    2005 MAGNUM SXT
    3.5 V6
    http://www.cardomain.com/ride/2390331
