Hi friends!
Please explain me what and where are those CV joints that should be inspected (said in the manual) at each oil change. Thanks in advance!
Hi friends!
If I throw a dog a bone, I dont want to know if it tastes good or not...
Constant Velocity Joints.They are next to the rubber boots on the axles and the only thing you can really inspect is the boot to make sure it's noot torn......beyond that if they are not clicking don't worry about them.
BFNY PERFORMANCE
RIP My Friend
yeh...someone didnt check mine and it blew up last year at 70 mph...the seal tore open and the joint just locked due to lack of lubrication.
Mabel
'05 Dodge Magnum R/T AWD
345 Cubic inches of HEMI power!
'98 Land Rover Discovery Series I:
4.0 V8: 182HP, 233 Tq
Traded in toward Magnum, sorely missed.
Guys I also have one more question. Where are those rubber seals on each side of the radiator that should be checked every month for proper fit? Thanks again.
the boots on both my cv joints are currently getting replaced as i sit on this computer at the dodge dealer lol... glad im still under warranty!
Guys where are those rubber seals on each side of the radiator that should be checked every month (says the manual) for proper fit? I searched but couldn't find them. Thanks again.
388 MAINTENANCE SCHEDULESNever knew anything like that was in the manual.
At Each Stop for Fuel
• Check the engine oil level about 5 minutes after a fully
warmed engine is shut off. Checking the oil level while
the vehicle is on level ground will improve the accuracy
of the oil level reading. Add oil only when the
level is at or below the ADD or MIN mark.
• Check the windshield washer solvent and add if
required.
Once a Month
• Check tire pressure and look for unusual wear or
damage.
• Inspect the battery, and clean, and tighten the terminals
as required.
• Check the fluid levels of coolant reservoir and brake
master cylinder, and add as needed.
• Check all lights and all other electrical items for correct
operation.
• Check rubber seals on each side of the radiator for
proper fit.
At Each Oil Change
• Change the engine oil filter.
• Inspect the exhaust system.
• Inspect the brake hoses.
• Inspect the CV joints and front and rear suspension
components.
• Check the coolant level, hoses, and clamps.
www.ramtruckforums.com
Have not had a look at my rad but is the manual talking about trans. lines [seals] o-rings at the rad? I would not believe them to talk about rad mount bushings if any? Cal
SLP CAI, SLP Catback, SLP 25% underdrive pulley, 170 stat, Predator SLP tunes[2], Mopar TCM, no esp mod.
