Results 1 to 14 of 14
    BILLIARDBRAWLER's Avatar
    BILLIARDBRAWLER is offline LX Newbie
    Jul 2007
    Well, got back from dragway 42 after t stat mod...
    Last night I bought a motorad 176* t stat and installed it in less then 5 minutes. ( thanks Meister and sorry, but the guy that did the video too, I can't remember your name,but thank you...)....what an easy job w/ your help.
    Anyhow, before I was running 210*-215* by the time I got staged. I was running 13.5's 13.6's occasionally 13.3. this while running the .25 cent fan mod. After this install, I ran 13.3's and a best of 13.27 at 110mph...60' at 2.0...never ran more then 13.3's....so very happy. Temp while running fans went fron 179 to no more then 183 while staging.
    I ran the fans the whole time and got the dreaded code ( engine light ) ....do I pull fuse 11 to get rid of the codes?....will the puter have to re-learn all the beatings?....the b & g flash? And do I have to worry about closed loop...open loop?????
    And BTW.....beat a 6.0 GTO....smoked him...but something was amiss, 'cause he ran a 13.8 and I know they run better then that...last gto I raced got me by .2
    Also race a sts-v....no contest...got him by .5
    Had a piece of shmidt looking 5.0 run a 11.4 with a turbo....real sleeper....looked like it was going to the junk yard....I love that shmidt!!
    To find happiness............make others happy!!
    2006 300C SRT8
    B & G 2, AFE 2 cai
    .25 fan mod
    Diablo, 180 stat, bt catch
    2005 Mustang GT
    EricG is online now LX Guru
    Jul 2007
    Albuquerque, NM
    With the air last night, I'd say those are mighty good times!!! I'm running the MOTORAD 186 and never get a code, for my one time at the track I kept a steady 188-190. Now I don't know if the extra 5-10 degrees gives the car a little extra pep for you or not, but you may want to swap to the slightly warmer t-stat just to avoid having to clear the code all the time.
    You may be able to get that 12.9 this fall, keep rockin'!
    Eric
    2006 Chrysler 300C SRT8 SOLD.
    (all times on 255/45r20 street tires)
    - stock 12.94@109.1 2.00 60'
    - intake/exhaust/CMR tune/tstat/catch can
    12.54@112.1 1.93 60'
    - at 5300 feet in ABQ
    13.57@103.5 2.06 60'
    Jul 2007
    thanks eric,
    I read from Meister that every 10* is a .1th...but he did mention that that was anything over 190*...so, maybe your right...I'll try the 4128 motorad...just sort a sucks having to re-learn everything...
    How do you calculate the da? or corrected horsepower. It was 83* and about 700 ft.....thanks boss!!
    2006 300C SRT8
    B & G 2, AFE 2 cai
    .25 fan mod
    2005 Mustang GT
    Jul 2007
    Albuquerque, NM
    http://wahiduddin.net/calc/calc_da.htm
    http://wahiduddin.net/calc/calc_da_rh.htm
    A couple options to get at it depending on what humidity measurement you have and we need to get an altimeter setting of some other pressure measurement from the area. Once you get your da, convert your times here it here:
    http://www.hardtail.com/techtips/altitude.html
    What's the closest airport to the track? I can help if you need it.
    Eric
    Jul 2007
    thanks eric...cleveland hopkins would be closest airport....i also figured out i got the engine code from running the .25 cent while the engine is running and it saw no resistance.......looks like some more wot beatings!!
    2006 300C SRT8
    B & G 2, AFE 2 cai
    .25 fan mod
    2005 Mustang GT
    Jul 2007
    Albuquerque, NM
    The DA was in the neighborhood of 2600 feet, your best of 13.27@110 converts to about a 12.8@113.5!!!!!!!!
    Eric
    Jaak's Avatar
    May 2005
    DA calcs, the best mod out there!!!
    Great run!
    2006 Magnum SRT8 - 11.85@117
    Jul 2007
    Quote Originally Posted by EricG View Post
    Eric
    No Smidt????!!!!!!......That's freakin' Awesome!!!!!!!!......That makes my whole day!!!!!!!........WWWWWHHHAAAAAAAAAHHHOOOOOOOOOO!! !!!!!!
    Thanks alot Eric!!
    2006 300C SRT8
    B & G 2, AFE 2 cai
    .25 fan mod
    2005 Mustang GT
    mluker's Avatar
    mluker is offline Geek Master Flash
    Apr 2006
    Minnesota
    Nice!!
    // Mopar CAI // 35% Tint // Zoomers Catback Exhaust // Honeycomb Grille // daytona oem spolier //
    Don't miss another Bag of Crap!
    Jul 2007
    UUMMMMMMMMMM........ ( tail between my legs )...................well, I convienently rememberd my best et and trap speed.....unfortunately, they were on different runs.
    So, After looking at my time slips...the 13.27 run actually had a trap of 106.5.....So I'm guestemating an adjusted maybe a 12.9? 13? make sence????
    2006 300C SRT8
    B & G 2, AFE 2 cai
    .25 fan mod
    2005 Mustang GT
    Jul 2007
    Albuquerque, NM
    Times and speeds are corrected separately. Check out this link again:
    Go to 2600 feet and multiply your speed by the correction factor. Funny how the best et's aren't always associated with the best trap speeds.
    Eric
    Jul 2007
    Eric
    Thanks Eric....looks like adjusted 12.86....and 109.96 .....thanks for the web page...saved to favorites.....
    Trying to rack my brain of how to get faster without fi or nitros.......maybe my leaf blower tied into the air filter???????
    2006 300C SRT8
    B & G 2, AFE 2 cai
    .25 fan mod
    2005 Mustang GT
    JMatt is offline Faster than the fastest 3rd Gen Hemi
    Nov 2005
    You've got more speed in there still.
    Keep coming until your engine temp is 165. To do this, turn your car heater on full blast. Turn your fan mod on. Every 5-7 minutes, turn the engine on just long enough to stir the coolant around - maybe 30 seconds. I leave it on just long enough to get my voltage back up to 13 volts.
    Your ideal engine temp should be about 165 when you start your drive around the water box. By the time you do a brief burnout and stage, your engine temp should hit 170 degrees.
    Your goal should be to launch with the engine temp right at 170.
    I'd put money on shaving an additional .10 seconds off your current best 1/4 mile time, even with the same density altitude.
    Jul 2007
    thanks jmatt......I'll sure try that next time...actually went tonight but I took my miata to see which would be faster...ran a 13.3 @ 107 in it. Man are they close!!
    Been following your nitros thread...I admire you taking on that job...I definatley would of been nervous.
    Any other tid bits for speed??....I'm addicted....it's all I think about all freakin' day long!!!
    2006 300C SRT8
    B & G 2, AFE 2 cai
    .25 fan mod
    2005 Mustang GT
