Results 1 to 2 of 2
    xk49's Avatar
    xk49 is offline LX Padiwan
    Nov 2008
    USA
    Vacuum Hose Location
    Where is the vacuum hose and/or compressor bypass valve? Is this the hard plastic hose thats on the drivers side of the intake manifold and attaches to the manifold right behind the throttle body?
    I need to tee into this hose, but I can't find any reference in the service manual for "compressor bypass valve".
    "Just because that's the way it is, doesn't mean that's the way it should be."
    2007 MSRT8, FlowMasters 40's, Vortech V3 SC, Magnaflow Hi-flows cats, BC coilovers, Hotchkis F/R Sways, Razors Edge Strut Brace, DMH cutouts, Silver Box, BT Catch Can and Engine Bling
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by xk49 View Post
    No that is the gas tank vapor return line. On the RT's, the vacuum hose attatches to the back side of the intake.
