Page 1 of 4 123 ... LastLast
Results 1 to 15 of 52
    imahemi is offline ...
    Feb 2007
    Omaha, NE
    Exclamation Upgrading Grounding Cables...
    I decided while I am doing all my stereo work that I would upgrade the ground cables.
    This process should be the same for all LX's with the 5-speed nag-1 transmission
    Tonight I finished up so I got more pics of the process...
    Rear Cable from battery to chassis...
    first remove the stock cable there is (2) 10mm nuts, one on the battery, one on the body
    Thumbnail
    Click to view the original image
    here is the stud on the body...
    Thumbnail
    I replaced the cable with a #2 awg ground cable... I used a 12" cable...
    Thumbnail
    comparison of the stock cable to the new cable...
    Thumbnail
    Cable from shock tower to top of bell housing (transmission)...
    here is the top mounting point... remove the 10mm nut here...
    Thumbnail
    I then jacked the car up...
    Thumbnail
    found the bottom mounting point... remove the 13mm nut here...
    Thumbnail
    Thumbnail
    here is the stock cable it is 24" long...
    Thumbnail
    I then got a #2 awg ground cable. since I couldn't get one with 2 ring terminals on it I cut the battery post end off... I used a 25" cable
    Thumbnail
    I also bought #2 battery cable lugs
    Thumbnail
    crimped the end on then added heat shrink...
    Thumbnail
    Thumbnail
    finally I got the cable installed...
    top...
    Thumbnail
    bottom...
    Thumbnail
    -Ryan
    -Ryan
    <<<clicky...
    '93 1500 SB - 240k, '05 Magnum RT - 18k, '80 El Camino - 86k
    Magnum P.I's Avatar
    Magnum P.I is offline WTF is that?! Let's call it a 300Wagon..
    Jan 2008
    LX & LC Nation, Brampton, Ontario
    pardon the silly question,but what are the benefits of doing this..Doesn't seem difficult to do..
    06 SXT AWD Magnum, Silver Steele Metallic: Chrysler's Red headed stepchild!!!
    I drive mine like I just left the bank after an unapproved forced permanent loan ...
    Feb 2007
    Omaha, NE
    main deal in our cars is the stock cables are very small...
    here is a google explaination...
    As many of you know, upgrading the "Big 3" wires in your engine compartment can lower the overall resistance of your entire electrical system. The effects of the lower resistance are typically:
    1) Reduced dimming and smaller voltage drops
    2) More stable voltage and better current flow
    3) Less strain on your vehicle's charging system
    SMKG HOT's Avatar
    SMKG HOT is offline Finding the Line - Semper Fi
    Great Post and nice info...............
    RP's coming your way.
    Laguna Seca 1.56.24 (4-22-08) 52*F 300C/SRT8 SVS Tuned
    398.91 RWHP / 394.08 (ft/lbs) Torque - (2-21-09) N/A 6.1L Stock Heads & Internals
    fnkychkn's Avatar
    fnkychkn is online now genuine factory cercumsized sh!tforbrain
    greasy cardboard box
    a couple of tips:
    1- clean any paint/e-coat from grounding studs.
    2- crimp and solder the cable lugs. crimping alone may not be enough. starter draw goes through this lug.
    dformer's Avatar
    dformer is offline POP'N TRUNKS ON PUNKS.
    Jul 2007
    HOUSTON,TEXAS
    swwwwwweeeeet.
    Bill_in_Wilsonville's Avatar
    Bill_in_Wilsonville is offline <= That's my dog, Emma
    Wilsonville, Oregon
    Great post imahemi!
    a couple of tips:
    Hey fnky,
    I'm thinking of upgrading the cables too. The rear cable is a no brainer, will do exactly as posted above.
    I'm looking for an easier way to do the front cable. I'm thinking of adding a second cable rather than replacing the OEM. Maybe connecting near the alternator and then to the body using existing bolts. Does this sound reasonable?
    Previously known as 'alpha' and 'b.71'
    Feb 2007
    Omaha, NE
    Quote Originally Posted by alpha View Post
    Great post imahemi!
    Hey fnky,
    if you get the cable before hand and have a set of ramps or a jack and jack stands this cable can be upgraded in no time. the hardest thing I had was getting the trans tube support moved enough to get the cable on and off the stud.
    -R
    Wilsonville, Oregon
    Quote Originally Posted by imahemi View Post
    -R
    Thanks for the info. Please understand I wasn't bashing your method .
    I appreciate the pictures you posted and they got me to thinking about how to get the same improvement with a bit less effort
    Again, great post!
    BlackCharger06's Avatar
    BlackCharger06 is offline Black Charger 06
    Boston
    So did it fix any of those problems
    <img src=http://i84.photobucket.com/albums/k8/brian_pahlm/wheels/new_england.jpg border=0 alt= />
    Audio Mods
    Alpine Iva W205 w/ 6 disc changer Alpine pxa-h701 Processor JL audio 450/4 JL audio 500/1 JL audio 10w7 Boston Acoustic SL95's Hertz MLk 2 Componets PowerMaster d3100
    Other mods
    Hood Strut Mod Daytona Grille R/T BadgesRetro Charger Deck Badge Ct Cruzer (Blastin Bob's) Custom Exhaust, What's next????
    Feb 2007
    Omaha, NE
    Quote Originally Posted by BlackCharger06 View Post
    I didnt have any of those issues... I did mine as a preventative only
    B-Digital's Avatar
    B-Digital is offline The Man, The Myth, The Legend
    Jul 2008
    Ottawa, Ontario, Canada
    lol i noticed the other night while my car was warming up, i pressed the 1 touch window down button and my headlights dimmed...
    would this fix that?
    Hemi Registry #1495
    Stuff a pony's hood with one of the multi-throat-carbureted monster motors, and it could fog the landscape with testosterone and tire smoke
    The Tran's Avatar
    The Tran is offline Oh yeah baby!
    Texas
    Great info. Doing the BIG 3 is always beneficial.
    If you're not rockin BT Stuff...You're just not rockin!
    www.custombilletstore.com
    MdotCline's Avatar
    MdotCline is offline Jesus Chrysler
    Dec 2008
    Danville, IN
    I'm going to do this for preventive maint as well - nice writeup, thanks!
    397 Stroker - ProCharger - BRING IT!
    fnkychkn's Avatar
    Great post imahemi!
    Hey fnky,
    don't see why not. just make sure you get good contact for low resistance connections.
