Originally Posted by
Super T
Mine would do a stellar braketorque ----> burnout transition... You did turn the ESP off, right? Wider tires or larger diameter tires will hurt your chances of fogging up the block, but you should definitely still be able to light 'em up. If the car happens to have under 300 miles on it, know that DCX built in a nanny to keep you from abusing it before it's broken in. If you have more miles than that, and stock tires, they should be long gone by now :-) Braketorque it some and see if that helps. And who cares if it's practical... it's fun!
Should have included this information in the original message I guess, live and learn..
Its a stock 2006 R/T, about 4700 miles. I got it with about 3500 miles on the clock. Stock rims/tires. I did turn ESP off and I tried brake-torquing it, but it just hooks up every time without even a chirp.
It will squeal 'em around corners, but thats not really what Im going for. It seems from what I'm reading here that some 'got it' and some don't.
There wasn't an option for a taller rear end gearing in the R/T's, was/is there? They're one size fits all, I thought.
I just got my K&N typhoon in, will install it this weekend. Maybe after that and the superchip I'll be able to waste some money by leaving rubber all over the road.
2007 Magnum SRT8 Steel Blue Metallic/Option groups 1,2,3/Roof Rack/Sirius/Everything but VES
2006 Magnum R/T - GONE!
