Results 1 to 15 of 16
    Super T's Avatar
    Aurora, IL
    U1417 - "Unknown"...
    Got a slight grinding feeling feeding back in my brake pedal, then ESP and ABS lights (nothing else) and this code. Cleared the code, got about four blocks, same thing happened again so I parked it. Weather was cold but dry. Only other code was a P0300 Random Misfire but that pops up once every month or so from the cam.
    I searched and consulted some other members. Ekaz pointed me to a thread on Chargerforums where the cause ended up being a loose axle nut (that scares me). Couple threads here lean toward wheel speed sensor.
    I'm wondering if anyone has experienced this code more recently, and if so, what was the cause/fix? Going to pull my drivers side rear wheel when I get a chance and check the axle nut (no time w/ holiday madness this weekend) but if that's not it, then I doubt I'll be able to diagnose as that would leave electrical gremlins...
    HemiPowered5700's Avatar
    HemiPowered5700 is offline Raging Inferno
    Mar 2008
    Chi-Town
    eh, wouldn't worry about it...just means your car is slow.... :-)
    lou1355's Avatar
    lou1355 is offline Hoosier Daddy - Finder of Weak Links
    May 2006
    South Florida
    I got that code and it's brother, U1418, Right Wheel Speed Improbable, when I went through the traps at the Texas Mile at 182+MPH. My axle nuts were tight as hell though. Staying below 182 MPH has cleared things up for the moment.
    Super T's Avatar
    Aurora, IL
    Quote Originally Posted by HemiPowered5700 View Post
    Hey pal, you have no room to talk yet. When are we fixing that, anyway?
    Quote Originally Posted by lou1355 View Post
    LOL... well, I assure you that wasn't my problem Wish it was! But interesting... so yours may have been a genuine case of "what the f*** is going on?" on the computer's end. Hmmm... That kind of supports what I've been starting to think - the code is incredibly vague and not very helpful at all
    Mar 2008
    Chi-Town
    cam is coming within a week or so i think.
    Super T's Avatar
    Aurora, IL
    Bump, no silver bullets for this one, huh?
    Tbird100636's Avatar
    Braintree, Massachusetts
    Cool
    U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED
    For a complete wiring diagram Refer to Section 8W
    • When Monitored:
    • Ignition on.
    • Set Condition:The PCM gets an implausible signal over the CAN C circuit from the ABS Module or FCM (NON-ABS). The circuit is continuously monitored.
    Possible Causes
    -VEHICLE SPEED SENSOR FAULT ACTIVE IN ANTI-LOCK BRAKE MODULE
    -CAN C BUS CIRCUIT SHORTED
    -CAN C BUS CIRCUIT OPEN
    -ABS MODULE
    -PCM
    Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING).
    Theory of Operation
    The ABS Module or FCM (NON-ABS) sends an implausible distance signal over the CAN C Bus circuit to the PCM.
    Diagnostic Test
    1. ACTIVE DTC
    NOTE: Diagnose all CAN B and C communication failures before continuing.
    Ignition on, engine not running.
    With a scan tool, read DTCs.
    Is the U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED active at this time?
    Yes
    • Go To 2
    2. ABS MODULE IS ACTIVE ON THE CAN C BUS
    With the scan tool, select ECU View.
    Verify that the ABS Module active on the bus.
    Is the ABS Module active on the bus?
    Yes
    • Go To 3
    • (Refer to 8 - ELECTRICAL/ELECTRONIC CONTROL MODULES - DIAGNOSIS AND TESTING) for No Response diagnostic procedures.
    • Perform BODY VERIFICATION TEST – VER 1.
    3. DTCS STORED OR ACTIVE IN THE ABS MODULE
    Check for wheel speed DTCs in the ABS Module or FCM (NON-ABS).
    Are any DTCs active or stored in the ABS Module/FCM?
    Yes
    • Refer to the appropriate section and perform the diagnostics for the DTCs.
    • Perform ABS VERIFICATION TEST – VER
    • Go to 4
    4. ACTIVE DTCS IN THE FCM
    With the scan tool, select ECU View and select FCM.
    With the scan tool, read active DTCs.
    Are any Communication DTCs active in the FCM relating to the ABS System?
    Yes
    • (Refer to 8 - ELECTRICAL/ELECTRONIC CONTROL MODULES - DIAGNOSIS AND TESTING) for the diagnostic procedures.
    www.ramtruckforums.com
    Super T's Avatar
    Aurora, IL
    ^^^ Hmmmm..... "With the scan tool"... that means I'm paying someone to look at this (assuming the axle nuts are tight)?
    Cool
    Yep, or finding a forum member local to you who has a StarMobile.
    Super T's Avatar
    Aurora, IL
    Quote Originally Posted by Tbird100636 View Post
    Might be able to sweettalk a dealer but I doubt it. *sigh* Looks like I know where I'm going in the Spring
    Super T's Avatar
    Aurora, IL
    Well here's a sad update... I believe my tone ring is damaged to the point that the sensor is starting to have a hard time reading it. I won't say how it happened, only that it's unfortunate that it couldn't stay on the Track Killer axle that was in the car until someone *cough* CMJ *cough* took it back.
    Anyone have a spare axle, any trim level?
    FactoryD's Avatar
    FactoryD is offline Gettin' high on the downlow
    Nov 2005
    Phoenix, AZ
    Same exact symptoms, same exact code.
    Stock axles. Hmmm.
    If it's the tone ring, I have no clue how it happened. :(
    bigkevin20's Avatar
    bigkevin20 is offline I like them natural and heavy!!!
    Oct 2004
    PA
    I had that code and it was a loose axle nut.
    HEMI!, Diablo Predator CAI tune SOLD, "GIGANTICAI" CAI, Blastin Bobs 7db , 22" 4inch LIP Velocity VW700 Rims on 265/35s SOLD, Chrome Grill, mirrors, pillars, handles and bumper inserts. Clear LED tails, 15" RE SX Sub, 7" Touch screen Navi, Ipod Control, TV Tuner, LED floor lights and license plate light strip, Reverse Camera,. FTP
    The "Giganticai"http://www.lxforums.com/board/f74/check-out-my-new-gigantic-diy-cai-112170/
    The Mag http://www.lxforums.com/board/f74/hear-my-baby-first-time-pics-75308/
    Chronic01505's Avatar
    Chronic01505 is offline I'M THROWED
    Sep 2007
    Maple Grove MN
    I had actually pulled that code only once Or it could have been a variation of it. With the abs an brought it to the dealer they said that my abs connector was properly seated. Havent seen the code again in 45k miles.
    2005 Dodge Magnum RT (RED)
    Features: Auto Lights, Chrome Vent Fins, Platinum Spark Plugs, MyGIG. Uconnect (08 LX Mirror) Alpine Solo X, Alpine 2000W Amp, Alpine 1000:1 Amp, 2 Rockford 500k- 1 faret total Cap
    Future Mods: 2Way Remote Start, Removal of the Roof Rack, (for sale if anyone wants it pm me) Superchip (not sure what one)
    ekaz is online now all gone
    Jun 2006
    CHICAGO
    Swing by me in the spring and I know a dealer that'll check it.
    Unlawful Gathering
    Click for details!
    2009 MBP GCSRT8
    Powered by PWR
    Shifted by SHR
    Tooned by Johan
    Blinged by Billet Technologies
