Turn signal stuck on.
When i turn on my turn signal on my 05 Magnum it does not click off when turning the steering wheel. After making the turn and turning the steering back into place I have to manually turn the signal off. Anyone else encounter this and what the remedy to fix it? Thanks
There's a physical cam-lock type mechanism on the switch... maybe it's worn out, but it shouldn't be already...
new turn signal/wiper stalk, meaning that whole arm will most like need to be replaced..
my car does the opposit very seldomly, i will put the signal on to turn left, only happens when turning left, after i signal, sometimes if i move the steering whhel just a lil bit before turning, the blinker will stop completely untill i click it back and re signal to turn left, but its so seldom i dont worry about it..its just weird..
Thank You Haz
- You may not post replies
- You may not edit your posts
Forum Rules
