what the hell!? i just got my car back a week ago, and there is LX Blood all over the driveway... again!
05 Blk Magnum RT RWD,Window Tint, Mopar CAI, B&G PCM Flash, Magnaflow Cats, Borla 125, "HEARSE" vanity plate, AR/311 20" wheels W/Goodyear F1 245/45/20, 4X R1 D&S Rotors, LED tails, AAC Halo's suck - replaced with 402 motoring lights (sweet), Custom LED turns, Wired V1 W/Remote Disp, Kenwood Excelon 715dvd w/ NAV, iPod, 2x Diamond Hex 6.5, Eclipse Titanium DVC 12" w/custom enclosure, JL 1000/1, 2x JL 300/2, 2X Optima Batt. w/ Isolator, Rear Shaved, R Sylvania Turns
by transmission seal, i'm assuming you mean adapter plug o-rings.
there may be a tab on the adapter plug that needs to be cut off to prevent repeat occurence of the leak. if they didn't cut it off, it could be the cause. i've also had to replace the entire adapter plug assembly because the old one was warped/deformed.
Wowsers.....feed me General.
2007 Road&Track ChargerBillet Technology*AMG paddles*AFE II*Jina SSEEibach&Koni*FR wheels*SRT8 hood #993*PredatorDanko*Hurst paint & body*Wings West
Mine is currently in the shop getting the same thing repaired. Should have it back next week, at least they gave me a Charger as a service loaner.
The same thing happened when we had the seal fixed. It took them a second try to get it right, but it's held ever since.
Crazy that happened to you because, THE EXACT DAMN THING HAPPENED TO ME.
Walk out one mornin to a trany fluid puddle....crap...off to the dealer. Fixed up lickidy split. Not a week later I go out to head to work and...WFT, again????
She made it till her death on the second one
2006 Charger R/T R&T Black..SRT8 stuff/JBA stuff
2005 Magnum R/T inferno red-now in magnum heaven
1966 Galaxie fastback-C6 w/460BB..sold, but not forgotten
Man do I feel for you guys. Is'nt that just too damn suspicious. I am fully convinced that these seals can cause you to get water in your tranny under the right conditions.
I got my Mag back today from my dealership/DCX war. They replaced my seals, even though I did'nt ask them, hunh?????????? They replaced them even though they said I had no leak there, hunh????????? Guess I better keep an eye on mine. for awhile.
Almost 11K on the Charger with no leaks.....yet
His Maggie that is in heaven...RIP
The water getting in the tranny is caused by where they put the drain for the evap core for AC and cowl drain.It would drain right on top of the dip stick,run down it and get through the seal at base.The fix is service the tranny,put new fluid,and put a shield over it to get to bleed away.
BIGDAVE
05 Magnum R/T RWD inferno red
Franks racing Sidewinder cam w/SRT springs
Flowmaster super 40s w/custom tails
SRT headers and Cats
PRO-TORQ 2800rpm STALL CONVERTER
for converter call (203)969-2886
