Results 1 to 6 of 6
Thread: Tranny Light
    Santagata's Avatar
    Santagata is offline LX Padiwan
    Jun 2008
    Question Tranny Light
    When I started my car last tonight the transmission light went on. It was on all the way home. When I started today it was out! Do you think something is wrong with my tranny? Has anyone else had this happened to him or her before?? *PLEASE NOTE: IT'S THE ENIGINE LIGHT!*
    The Unabomber's Avatar
    The Unabomber is offline LX Padiwan
    Aug 2007
    Transmission light? I wasn't aware there was a light dedicated to the transmission.
    Santagata's Avatar
    Jun 2008
    Wait sorry engine light!!
    Hal'sMag is offline Wax On - Wax Off
    Feb 2007
    L.A., Ca.
    Key dance
    In the KB, DMAG posted a thread to check for diagnostic codes - AKA Key Dance.
    The list of what they mean is in the thread also.
    Depending on what threw the code, a 15 sec pull of fuse 11 up front should clear it for now, if it set a code.
    I've had a cel that did not set a code and did not reappear.
    Just a grocery getter!
    Fargo59's Avatar
    first thought: did you just buy gas? if so, check your gas cap. those would be P0442, P0455, and p0456 codes displayed via a scanner, or in the cluster.
    fuzzycali's Avatar
    fuzzycali is offline Space City LX Nawfside AC
    SPRING,TX
    it could b numerous things. either way u have had good trips so the dtc went from active to stored and now ur light is off.u could still do the key dance to retrieve a code.give u an idea.
    2007 Charger Road & Track R/T
