Results 1 to 10 of 10
    MrAngry's Avatar
    MrAngry is offline LX Newbie
    Dec 2008
    Tire pressure monitoring system question - Need Assistance
    Hi guys -
    I just replaced the stock SRT wheels on my '06 Magnum SRT with those from an '09 Challenger SRT - my tire pressure system however is not reading the sensors in any of the tires and is throwing the "Check TPS" light. All wheels are coming up blank.
    Any ideas? Are these sensors coded per car or something? Or did the sensors change from year to year?
    Thanks - Mike
    SRT8NJ's Avatar
    SRT8NJ is offline 402...Where the Legend resides
    Dec 2007
    Tinton Falls, NJ
    Did you switch the sensors over and install them in the new wheels?
    Ken.. 2007 MSRT402 Tu-tone Steel Blue Metallic and Straight Gloss Black
    Mopar CAI, Jet 180, Diablo Predator, BT Catch Can, Corsa Cat-Back, High Flow Cats, Version (1) 402 Motoring Rear Spoiler, 402 Color Matched and Tinted Tails and Eyelids, Grip Rockers, MSRT Color matched Wheels, Vredestein 275 40's, "Soon" - Spartan Cam, 402 Motoring www.402motoring.com
    MrAngry's Avatar
    Dec 2008
    No - sensors in the new wheels are '09 Chally sensors.
    EPIC SRT's Avatar
    EPIC SRT is offline Go Daddy! GO!!!!
    Feb 2009
    Merced, CA
    Switch the sensors if you can. Otherwise I think you have take it to the dealership and they charge some bs amount just to read the new ones and reset it. I say bs cause my local dealer wants $130 to do it.
    06HEMIR/T's Avatar
    06HEMIR/T is offline Wrench
    Nov 2008
    Elizaville N.Y
    Your car may not read the Chally wheel tpms. Also when you move a sensor out of its original position you have to have the car relearn the new position. Check your owners manual it tells you about tpms system.
    Embroidered Leather Console Cover BY JINA, Dynomax Mufflers, Reso Delete, Superchips, Bt Front & Rear Badges, True Cold Air Intake TruFiber 3" Cowl Hood, FlashTech Halo's ( The Best Halo's Around)
    carchitect's Avatar
    carchitect is offline has been pardoned by the language filter
    Morton Grove, IL
    Quote Originally Posted by MrAngry View Post
    Hi guys -
    Thanks - Mike
    There was a change in the frequency that the TMPS sensors transmit. I'm not sure what year they did it though. I know that the the Challenger (LC platform) and the Magnum (LX platform) don't share the freq's.
    These are what you have
    http://www.moparsupercenter.com/tire...c.html?cat=757
    These are what you need. I'm not sure why these say "thru 2010" though.
    http://www.moparsupercenter.com/tire...b.html?cat=757
    2006 Inferno Red Charger R/T|Zoomers|C&L Intake|Retro Mag 500 Wheels|Pedders Touring Plus w/ adjustable camber|General Grabber UHP 255/55/18|Flat Black Daytona Grille|BT Catch Can|SRT-8 Rear Diffuser|Mopar Chin Spoiler
    MrAngry's Avatar
    Dec 2008
    Can I transfer the sensors from the '06 Magnum wheels to '09 Chally wheels? I know these wheels came stock on '08 Magnums SRTs.
    EPIC SRT's Avatar
    Feb 2009
    Merced, CA
    You should be able to! That is what I did with mine and I have had no issues.
    I think I posted in one of your other threads, I have an 06 mag with 09 chally wheels.
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Superchips has a new program out for their flashpaq that lets you turn them off.
    Super T's Avatar
    Aurora, IL
    You can swap the valve stems between the two sets of wheels and remount/balance for about $175 at a dealership. Like they said, different frequency effective 2008.
