Results 1 to 9 of 9
    notabadlookincar's Avatar
    notabadlookincar is offline Notabadlookincar
    Nov 2006
    Rochester,ny
    tire pressure with bfg tires?????
    hey guys,
    anybody running bfg kdws 245/55/18??if so what tire pressure should i run in them.....
    thanks in advance
    Dodge Charger R/T - Road/Track group,30% tint,Mopar CAI,Superchips,Zoomers,Silverstars,245/55/18 Bfg kdws,Honeycomb grill insert,red R/T emblems,front and rear fascia... all options available except block heater and protection group.....305.71rwhp and 345.42rwtq,air temp 87F
    BobF's 6POINT1's Avatar
    May 2004
    PHXAZ
    Always run tires at the recommended pressure on the car, not the tire. It's listed in the driver's door jamb.
    Ours are 32lbs. 32-35 usually works well.
    Monster's Avatar
    Monster is offline ME-(I don't see the resemblance)-OW
    I'm That Neighbor You Hate!
    I have mine inflated to the factory recommended 30 psi, listed on the door jamb. The place where I bought my BFGs uses only nitrogen for filling the tires. I've had mine for about 2 1/2 months, with excellent results.
    I Am Not A Complete Idiot!!! (Some parts are still missing!)
    Pale Rider's Avatar
    Pale Rider is offline Magnum Come Loudly
    Mar 2006
    Western WA
    I have KDW2 (not S)
    I like to run them at 37. Sometimes I go 40-45 for longer trips. But that's too harsh for my tastes around town.
    I feel that 34 or under is just too soft. I can really tell a difference between 34 and 37 in the corners, and in the gas pedal.
    If you have wider than stock tires, keep in mind that Dodge gave you a presure statement about your stock tires, not the widest you may use. A wider tire that's under inflated, or at stock pressure, may be not making propper contact in the middle, and cause bad handling in the wet. (and of course tire wear)
    2006 Stone White MRT
    Sidewinder Cam, Mopar Long Tube Headers, Magnaflow Cats, Magnaflow Mufflers
    13.422 @ 102.84
    All that and a CHROME instrument bezel! YES!
    hondaman9468's Avatar
    hondaman9468 is offline 05 r/t cool van.
    woodstock, GA
    In my bfg 255/55/r18 i run 34psi....
    FloridaRT's Avatar
    Ocala, Florida :-)
    I run my 255x55x18 at 36 psi.
    Bob
    MikeEast's Avatar
    Ducktown, Georgia
    BFG KDW2 255/55-18, was running 40 psi and it handled great, rode a bit stiff and wasn't as noisy at real low speeds as they are at 36, where they are now.
    I mainly went higher to eliminate the low speed rumble and gain the handling - but secondary to that is my distaste for tires that wear the edges first - like the Conti's did. So I put more wear in the centers for 20K miles and now I'll soften them up and wear out the edges...
    Mike
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    I had the 255/55's and I ran them at 34 psi....they seemed to wear more in the middle though. Maybe 32 would have worked better.
    cadzilla74's Avatar
    cadzilla74 is offline Does this smell like chloroform to you?
    Jun 2005
    FTW TX
    12,000 miles on 255-55-18 HDW2's. I run 36psi. Treadwear is even and the tires handle much better wet or dry than they do at 30-32psi which they were at for a total of a week when I first got them.
