Results 1 to 15 of 15
    zbeest is offline LX Newbie
    Nov 2006
    Tire going flat but no bubbles???? :)
    So I get home from work yesterday and notice the front drivers tire looks a little flat. Get the gauge out and it's about 13psi! Hmmmm, check the others and the other front is about 26psi and the rears are bout 34... pump them all up to 40 psi and check the bad tire for obvious signs of a nail and find nothing....
    Visual check when I wake up this am and they look ok so I drive off to work and leave it for the day...Come out and notice that its low again so get the gauge out and it's reading 10psi! Drive it to the closest gas station pay my 50 cents and inflate to 40 psi again.... drive it home ( less than 1hr or 60km) and find it's pretty much flat again.... WTF.....Take rim off and inflate to 40 psi and then dunk it in a kiddie pool and watch for bubbles......Watch and watch, give it poke, flip it over ,play with the stem, flip it over again and watch it some more. Still no %#$! bubbles!
    Close inspection for rim cracks or nails and find nothing...
    They are Viper 20 x 9" chrome rims with Toyo Proxes 245 tires if that makes a difference. I can't figure out how the hell I can lose 30 psi in less than an hour and NOT see any damn bubbles.... Ideas?
    Will see how it is tomorrow morning again.....
    Chris
    '06 Black Magnum RT, 20" Staggered Vipers, Mopar lowering springs, SRT8 headlights, 22 Elite console cover, re-arranged badging, tinted front windows, blacked out grill, $14 bumper chrome mod, Super Chips, Magnaflow cat back, AFE II CAI, R1 Concepts slotted and drilled premium rotors.
    My cars and home theater
    Photobucket pictures of various things
    Zoban's Avatar
    Zoban is offline lil Red Wagon
    Feb 2008
    Oshawa Ontario
    Might be a bead leak that only actually leaks when there is weight on it to stress the bead seal..
    Had a similar issue with my PT after a few re-seal attempts I got ticked off and used one of those crappy tire cans for road side (only a portion of it) and went for a drive .. never leaked again..
    2006 Lil Red Wagon SXT
    Modlist : AFE Stage II, JBA Headers, Corsa Catback, 20" Vipers, Cross Drilled Rotors, Diablo Bob@SVS Tuned, Pioneer DEH-5000UB, 12" Enclosers, Halos, Low/Fog HIDs, Cuda Grille, TruFiber Chally Hood.
    at the Track
    My Garage
    Mentoria Computer Consulting
    DonH's Avatar
    DonH is offline Enough and no waste is good as a feast.
    Jacksonville Fl
    Or it could be something stupid.
    Could the valve stem cap be pushing down on the valve stem letting out air? Some caps have a little O ring inside, when dislodged it will cause air to escape.
    Don
    The "UN"club
    We have two rules, Love Cars and Have Fun!
    AirHammer, Zoomers, Predator, 20% Front Tint, GTS Vent Visors, In-Motion Nav Hack, Glove Box Light, Interior Aluminum Door Trim, Billet Catch-Can, Front Passenger Grab Bar .....
    Mr. Magnum Man's Avatar
    Mr. Magnum Man is offline Gone Fishing
    Jun 2004
    Long Island
    Its me I sneak over and let the air out when your not looking. Seriously itc ould be the bead it can shift with the cars weight on it over inflate it to 60 lbs and spray with a soapy water mixture. Return to proper pressure before driving.
    '05 Ddoge Magnum RT
    '06 Dodge Ram 1500 Night Runner
    2 Hemis with the gas nearing $3 I must be crazy
    Daytona 226's Avatar
    Daytona 226 is offline My Other Boat is a Sea Ray!
    NJ
    I recently went through this on my other car. It was the bead. Tire place shifted it slightly, and all is good now.
    Mods: FRI Street Heads, Sidewinder, Zoomers, Mopar LT's & Hi Flow Cats, DS Predator, DSS Axles, Ram Air Hood, Hotchkis Sways, noESP, Coolit, TranZformer, Dynamic Grounding System, Autometer C-2's, Rocker Panel and Rear Fascia Decals, Tinted Tails, Zinik S-21 Chrm. & Blk. Staggered 20's, Grip Rockers, Power Slots, Centric Posi-Quiets, AAC Halos, Billet Tech., BFNY'ed, RDP Racing Tuned, Ridergraphix, Electronics by Joe@402Motoring
    FloridaRT's Avatar
    Ocala, Florida :-)
    Probably the bead seal, could also be some corrosion where the tire seals against the rim.
    May have to take tire off of rim, inspect rim seating area for corrosion and remount tire.
    Bob
    Nov 2006
    Well, I went out this morning to check the pressure as it "looked" ok. Went to unscrew the cap and ended up pulling the guts of the valve out! Looks like the glue that bonds the brass part into the rubber has failed. I had to jam it back in to inflate enough inorder to get a jack under the car.... Swapped a winter rim/tire over and dropped the Viper off to get a new valve asm installed. That will also take care of any bead issue..... I don't think the valve was leaking, unless the cetrifical force of the spinning wheel was somehow contributing to it....Either way, it's getting a new valve and the bead reseated....Just hope they don't scratch the rim!
    Chris
    FloridaRT's Avatar
    Ocala, Florida :-)
    The valve stem core "screws" into the valve stem, no glue is used.
    Need a special valve core stem tool to screw it back in.
    I have a couple in my tool box.
    Bob
    Nov 2006
    I can assure you that this one was glued in...
    I stood there holding it in my hand as the tire went flat in about 5 seconds.....
    This must have been a cheap stem or the part that you were refering to was part of another assembly -that fits into the rubber part....
    Chris
    CREMATOR's Avatar
    CREMATOR is offline RIDE: 06 R/T BBCP
    Feb 2007
    Ingalls, Indiana
    huh, maybe when you had them installed some numb nutz messed it up and tried to put some kind of sealer in there to get it by for a while.
    Randy '06 R/t, Brill Blk with lt sla int, cd, with Elect conv grp, Conv grp II, and Prot grp, Pwr sunroof, 600w pwr inv, Hardwired Radar Detector and Sirius Sportster, Tinted Windows, CAI, Tail light Night shades Blacked out, Restraint decal, Led plate screws, seq tails, back lit wheels, back seat mood lighting, sheriff sticker and Danko Chin Spoiler, and Led Eyebrows, and led back up lights, Led trunk overhead lights, currently in shop, wrecked. New mods coming soon
    t.
    stitchmonkey's Avatar
    stitchmonkey is offline What's up Doc? Who's drivin this thing?
    Feb 2007
    It rubs the lotion on it's skin, or else it gets the hose again!
    I have the same, almost same problem. One of my rears loses presure over a few weeks.
    4DEATER's Avatar
    4DEATER is offline Arfur's Nemesis
    Feb 2007
    Lima, OH
    Quote Originally Posted by stitchmonkey View Post
    I had that with my tires when they mounted them at the show in Columbus. It was the needle valve. It was over tightened. They have an actual needle valve torque wrench for that. I didn't know that.
    "Even those who arrange and design shrubberies are under considerable economic stress at this period in history". Robert the Shrubber
    Nov 2006
    Seems to be fixed now.. Been fine for past couple of days.... Could have been the bead but the valve was toast for sure...
    Chris
    Jun 2004
    Long Island
    Wow this thread still on the front page. getting more life then my Conti's. Glad you found the problem.
    '05 Ddoge Magnum RT
    Big RobsR/T's Avatar
    Big RobsR/T is online now Biggest guy on the Forum
    Apr 2006
    Houston, TX
    My front tire slowly loses pressure over a couple weeks as well. Im not sure what it is. I had a blowout in Louisiana and had to get some cheap tire at a store in a small town so I could drive back to Texas. Funny because my previous tires I had on for 35000 miles and they never lost pressure.
    2009 Stone White Challenger R/T 6-Speed
    JLT Carbon Fiber Intake||180 Jet Tstat||85mm ported throttle body||Predator||Petty's Garage Strut Brace
    SRT hood scoop inserts||Billet Tech Hood Emblem and Door Sill Plates
